mickymost
Doesn’t seem to clog mine, been doing it a couple of years and emissions are spot on![]()
Nabsim did you say you drive a Mercedes Sprinter?If so interesting.
Yes my coachbuilt is based on a Sprinter 316 2.7 5 cylinder. It’s a Tn1 chassis/engine although complete unit is 2007Nabsim did you say you drive a Mercedes Sprinter?If so interesting.
Can’t really say on that as I have used it since before I discovered my right foot had a drastic effect. I had a typo in my earlier post, it’s should have said if I keep speed at 60mph and under I can get 30mpg, if I run at motorway speed this drops to around 25mpg. Most of this year has been spent parked up so I have probably used as much diesel running my Eberspacher as I have running the engine so can’t say if anything has changed although no reason for it to have doneThank you.Mine is a 2004 Van Conversion Sprinter 313cdi so I may try the redex then as it seems it works.Does it help with MPG?
Oil (and filter) changes anytime (about every 5000 miles on yours) - make sure the engine is hot before.Not interested in engines but this thread has made me think I need to give my 22 yr old a bit more TLC. Done some of my own reading and tbh am pretty much non the wiser on what I should put in
Due to ambient temps are oil changes best carried out in summer?
In leaner times I experimented with adding cheaper things to diesel. Engines with precombustion chambers were not that fussy. Direct injection were. I got a good deal on a drum of old sulphur diesel and my Merc 608 thought it was it's birthday. Faster accelerating and better mpg. My old petrol landrover would be happy with most things added to it petrol upto about 25%.Fuel wise, our diesel fuel pumps are not fussy at all (unlike modern common rail) - happy to run with a 50/50 diesel veg oil mix (in summer).
It’s hard to know true mpg unless you meticulously note down each fill and work it out properly. I will do it over maybe half a dozen (at most) to a dozen fill ups for an average, normally when I first get a vehicle or if changes have been made. Of course if I did the average poncing around Lincolnshire one month it would bear no reflection on the following month in the Highlands or similar.Two of the most lied about subjects in motoring, top speeds and mpg.![]()
The only one I've tried was the Lucas additive, was ok, but went back to Archoil D-max. Not sure about extra MPG but emissions went down and stayed down on MOT's, and the engine runs a lot smoother.Mmn !
Confused.com
5 Best Diesel Fuel Additives of 2023 (And Why They're Great!)
What is the best diesel fuel additive for your vehicle? Read our guide and let us recommend the best options on the market right now. Diesel fuel additives are chemicals, which are added to the vehicle’s fuel. There are several different strains and each delivers an array of unique benefits.oilandwaterproject.org
Anyone used any of these please.
If it gets cold ( below freezing ) might be worth reading up on adding kerosene to the diesel for your mongol tripNot interested in engines but this thread has made me think I need to give my 22 yr old a bit more TLC. Done some of my own reading and tbh am pretty much non the wiser on what I should put in
Yes same here and i put 2 bottles in my central heating tank, never have to clean jet or swirl cup, inside of boiler is as clean as a whistle.Doesn’t seem to clog mine, been doing it a couple of years and emissions are spot on![]()
Finally..will REDEX work with LINUX ?
We have the same vehicles 316 CDI coachbuilt. I decided to record fuel consumption on a trip through Yorkshire and up to Fort William. Taking it quite easy manually changing up the auto box at lower revs and keeping it under 60mph when cruising. I covered 839 miles between fill-ups and averaged 23.77mpg. We are hauling about 4 tons around so maybe that and the hills makes a difference? I would be surprised if we get better than 26mpg anytime but will try just out of interest. Happy to just put fuel in whenever needed but don't worry about mpg as it is what it is.If I keep speed at 60mph and under I can get 30mpg, if I run at motorway speed this drops to around 25mpg.
