wildebus
you are making an assumption aboiut what is fitted and I think basing your thinking as if you had a cable from starter battery to habitation battery. There is usually on a motohome a low-current device connected by a thin cable.I understand what you're saying WRT using a B2B and you're right of course but I was considering what would happen with a straight swap to lithium with no modifications to the existing charge circuit, ie drop in lithium.
Yep, the current is flatter for longer with Li but the available voltage from the alternator is essentially boosted by the B2B in order to enable this. Drop in doesn't have the same advantage and your left with I=V over R and I can't see how the current can possibly go up when the voltage differential goes down.
You end up at best with an existing setup that is running at its full capacity for lomger than it is designed for and run the risk of it failing due to exceeding its duty cycle (problem 1) and then not outputing the voltage required anyway (problem 2).
Vendors promote Lithium as Drop-in. I just don't agree and that is my opinion on it. I think I have had this conversation with someone before on this forum and he had a go at me for not providing a dissertation for my reasons.
All I will say is each to their own but I would not reommend a Lithium Battery is fitted to a Motorhome with a charging system that is barely adequate for a Lead Battery whos charging needs are way lesser. If you asked me to fit a Lithium Battery to your motorhome with that setup, I would just not do so.
I would suggest rather than basing your calculations purely on Ohms Law for a theroretical answer, you need to consider what is physically installed and how they can be impacted (and the cost of repairs when things go wrong) due to overloading.
