wildebus
well that's the downside! (and add in cables, plus the solar panels themselves ...)Whats the total cost of that lot then fitted.
And?well that's the downside!
every install is different and takes different time and different amounts of kit.
Victron stuff in that picture? £2,000?
you will get 100ah lithiums with Bluetooth BMS and heaters for £389 now Barry from Alpha less your 7.5% discount on here. I paid £525 for mine from Alpha 18 months ago but they are cheaper now. Mine are the Polarmax low temperature models. This allows them to be charged below 5c as they have heaters.So add in say £1000-£1500 for the batteries and you are looking at £3k+ fitted? More than I imagined but presumably depending on the van and its age you might not need all of it?
Depends. I use 12v for telly, lights, ventilation, charging laptop, mobiles, etc. I probably take about 30Ah a day out of the system, which is something my 200W solar can replace for much of the year. However, lead/acid has a 'slopey' discharge curve and the original fluorescent lights don't work properly once the battery gets to half charge. OK, I've bought LED units but haven't got round to fitting them yet. LiFePO4 has a much flatter discharge curve and has a slightly higher voltage, so better suited to my needs. IOW, it isn't all about how much power but also about quality of that power.What is it that folks require all the power, surly a loo light and main cab light is alls required to read the benno at night.![]()
Trev is still trying to get his tongue out of his cheek Geoff.Depends. I use 12v for telly, lights, ventilation, charging laptop, mobiles, etc. I probably take about 30Ah a day out of the system, which is something my 200W solar can replace for much of the year. However, lead/acid has a 'slopey' discharge curve and the original fluorescent lights don't work properly once the battery gets to half charge. OK, I've bought LED units but haven't got round to fitting them yet. LiFePO4 has a much flatter discharge curve and has a slightly higher voltage, so better suited to my needs. IOW, it isn't all about how much power but also about quality of that power.
For me it was a no brainer Trev. I bought 3 of the Bosch Powerframe battery that were supposed to be the dogs danglies 6 years ago and killed them in 12 months. That was £360 in 12 months. I bought 2 x 100Ah lifepo4 and I am still using them with no degradation. They have paid for themselves more than twice over going off my first set lolWhat is it that folks require all the power, surly a loo light and main cab light is alls required to read the benno at night.![]()
Yes things move fast, years back powerframe was the dogs dangly bits, old hat now, im now working on a fusion newclear power pack.For me it was a no brainer Trev. I bought 3 of the Bosch Powerframe battery that were supposed to be the dogs danglies 6 years ago and killed them in 12 months. That was £360 in 12 months. I bought 2 x 100Ah lifepo4 and I am still using them with no degradation. They have paid for themselves more than twice over going off my first set lol
Yes things move fast, years back powerframe was the dogs dangly bits, old hat now, im now working on a fusion newclear power pack.![]()
Thank god I don’t live anywhere near you Trev.Yes things move fast, years back powerframe was the dogs dangly bits, old hat now, im now working on a fusion newclear power pack.![]()
I originally had the same view about 'drop in lithium' causing higher alternator charge current than lead, I've even posted so previously but when you think about it, in theory , the reverse will happen and for the vast majority of the charge cycle (except for the first few percent) the current will be lower with lithium than lead acid.You original split-charge system on a 2001 van *may* charge the Lithium better than a newer van oddly enough as it is probably just a straight relay. But with that you run the risk of exceeding its current capability as the old Lead Batteries mainly and the cabling to a degree used will essentially have been the charge bottleneck. Once you swap lead for Lithium, it will take all it can get, so you may find you are overloading the cable and blowing the fuse repeatedly, or overstressing the vehicle alternator.
AFAICT, and working from first principles:I originally had the same view about 'drop in lithium' causing higher alternator charge current than lead, I've even posted so previously but when you think about it, in theory , the reverse will happen and for the vast majority of the charge cycle (except for the first few percent) the current will be lower with lithium than lead acid.
Current = Volts ÷ Resistance.
The volts in this circuit is the voltage difference between the alternator and the battery.
The voltage at the alternator doesn't change and neither does the wiring resistance (there is a slight difference in internal resistance of the two chemistries but it pales into insignificance when compared to the wiring resistance so can basically be ignored)
So the single factor governing charge current is the battery voltage and as you know you provided me with lithium charge graph showing lithium extensively charges at a slightly higher voltage than lead acid....so the current MUST therefore be lower surely?
A little counter intuitive but it does explain the stories of drop in lithium charging very poorly and no stories of burned out relays, fuses and wiring.
Whadaya reckon?
Thing is though Geoff, it's not just the battery internal resistance that needs to be taken into consideration.AFAICT, and working from first principles:
V=RI (Ohms Law). Thus the current, I, is proportional to the inverse of the resistance R and directly proportional to voltage V. Now the internal resistance of a typical lead/acid battery is about 10 to 30 mΩ while the internal resistance of a typical LiFePO4 battery is between 1 to 5 mΩ. So even if the voltage difference between alternator output and LFP battery terminals is only half that for lead/acid, the current will still be much higher because of the lower resistance.
Nah, don't agree.I originally had the same view about 'drop in lithium' causing higher alternator charge current than lead, I've even posted so previously but when you think about it, in theory , the reverse will happen and for the vast majority of the charge cycle (except for the first few percent) the current will be lower with lithium than lead acid.
Whadaya reckon?
In any series arrangement, current is limited by the device that will pass the smallest current. As an analogy, consider a water pipe with an orifice plate. Without the orifice plate, the pipe can pass a lot of water; with the orifice plate, the flow rate is restricted by the orifice plate. Now in our alternator charging system we have four components (OK, five including the chassis for earth return):Thing is though Geoff, it's not just the battery internal resistance that needs to be taken into consideration.
Wiring resistance (both positive and negative) in the whole of the charge circuit, that includes quite a few metres of cable, relays, circuit board tracks fuses etc, Add it all up and you're looking at way more than either of the batteries, maybe 100-200mohms depending on cable gauge and length of run.
Battery resistance will have little effect compared to wiring resistance, it's wiring that basically controls the charge current, with either lead or LFP.
I understand what you're saying WRT using a B2B and you're right of course but I was considering what would happen with a straight swap to lithium with no modifications to the existing charge circuit, ie drop in lithium.Nah, don't agree.
You look at a graph of the current when charging lithium and you see maximum current for the duration until it is full.
You see the same graph for lead and it is quite different once lead has reached a certain level of charge (and that level is fairly low). Those graphs that are published showing this are accurate and i see the same thing for real in my van (and I can switch between lead and lithium at any time to evaluate this).
As far as having wiring as the controlling factor, no thanks.
