campervanannie
Help mine is stuck it will lock and unlock but when you twist it it’s not coming out is there a trick to unjam them I have a new one ready to replace once we can get the old one out.
Really? Stand by for the hazard tape then. Anybody remember this? https://wildcamping.co.uk/threads/emergency-repair.93895/#post-1310203yes ,give it a smack
don't worry , Annie knows how hard to hit things without causing permanent damage .Really? Stand by for the hazard tape then. Anybody remember this? https://wildcamping.co.uk/threads/emergency-repair.93895/#post-1310203
Yes we did fill it up this way but B need to replace it at some pointSounds like either the lock barrel had become detached or the inner mech has come unglued with the outer part, not sure what to do in either case, maybe try taking the key out if it's still in or vice versa, you may be able to fill up via the tank's cap if it's accessible, under a seat or under a section of the floor.
Deja vu ..........I've read several times of this happening, racking my brains to recall the remedy, was it pouring hot water on the cap?
I think the remedy you're thinking of is where the cap doesn't lock when you turn the key. The remedy is to drop the cap into hot water - it works and I've done it. In this case it can't be removed from the vanI've read several times of this happening, racking my brains to recall the remedy, was it pouring hot water on the cap?
When it happened on the Rapido the key wasn’t turning so we put graphite in the lock and after a bit of jiggling it freed itself, but on this van it’s locking and unlocking just won’t pop out.I've read several times of this happening, racking my brains to recall the remedy, was it pouring hot water on the cap?
You sure you did not leave your purse behind the cap, Annie, hence the reason it won’t openWhen it happened on the Rapido the key wasn’t turning so we put graphite in the lock and after a bit of jiggling it freed itself, but on this van it’s locking and unlocking just won’t pop out.
If burglar Bill can get the cap out they are welcome to the contents of my purseYou sure
Ours went just like that. The trick is to move it up and down, and gradually work it loose and pull it out. Using the key, in the lock as extra leverage helps.Help mine is stuck it will lock and unlock but when you twist it it’s not coming out is there a trick to unjam them I have a new one ready to replace once we can get the old one out.
Try dropping the van in hot waterI think the remedy you're thinking of is where the cap doesn't lock when you turn the key. The remedy is to drop the cap into hot water - it works and I've done it. In this case it can't be removed from the van
