GeoffL
According to the 'net, cell voltage at 100% SOC is 3.65V while charging and drops to 3.40V after resting. So, for a 4-cell battery (which is what I have), that's 14.6V and 13.6V respectively. Thus, unless the cells are perfectly balanced, an over-voltage condition in one cell seems possible. For example, if three cells were 0.1V lower than the fourth, 14.6V would be split 3.725V for the highest voltage cell and 3.625 for the other three. As you can see from the screenshots I uploaded, the differential is over 0.1V at 100% SOC although it's less than 0.005V at 80% SOC. Hence the cells don't appear to need to be massively out of whack. A 0.1V differential would be enough to trigger an over-voltage condition at just 14.3V...Hmmm, don't think that'll happen Geoff.
They suggest charge voltages of 14.6V so the BMS over voltage threshold MUST be higher and is probably considerably higher than this (3.65v / cell) and therefore alternator charging at 14.4 volts won't trigger cut off unless one cell is massively out of whack with the others.
Good luck with the Festival BTW, it looks great![]()
Thanks re. the festival: I got press-ganged into a shanty band a couple of months ago and I'm still busking for a lot of their repertoire; so that good luck might be needed :vbg:
