Lead Carbon has a different set of preferred voltages (they are actually closer to Lithium than standard Lead Acid) but it is close enough.
Is that close enough to lead acid or close enough to lithium?Lead Carbon has a different set of preferred voltages (they are actually closer to Lithium than standard Lead Acid) but it is close enough.
True, but no heavier than standard lead acid and arguably 1/2 their weight because they potentially have twice the useable energy density after you take into account the fact that Carbon batteries are far more tolerant of very deep (up to 100%) discharges.Lead carbon is very heavy, that’s a massive drawback for some
Is that close enough to lead acid or close enough to lithium?Is that close enough to lead acid or close enough to lithium?
What I want to avoid is this absorption phase that AGM batteries have and can they handle the maintenance charging phase?
I have been looking at lead carbon and the batteries do look interesting. Weight is not an issue as we have plenty of spare payload.
You can use either profile to charge carbon but you'll get slightly more into the battery if they receive an absorption phase too.
Why do you want to avoid the absorption phase?
Merl
Hi.KS Energy claim that their lithium batteries have built in charging management systems that make them a simple drop in replacement for a lead acid leisure battery.
We have a motorhome with a Sargent EC652 power box and built in transformer, a Fiat Ducato smart alternator, a 100w solar panel and a Sargent solar controller.
So can we simply disconnect and remove the lead acid leisure battery and reconnect and replace it with a KS lithium battery?
Without doing a single modification to any other component?
A simple yes or no please if possible together with any user experiences of KS Lithium batteries if possible.
The Sargent PX300 original equipment charger in the EC651, whilst it has 3 phase charging, it does not have an absorption phase. I simply want to substitute a lead acid battery with something better without having to replace any of the charging equipment.Is that close enough to lead acid or close enough to lithium?
Merl
Of courseDoes it matter, if the OP want to avoid it then it`s their decision and so be it.
The Sargent WIll have an absorption phase mate (on any non lithium setting) it may be called something else by Sargent though, probably the 'constant voltage' stage, same differenceThe Sargent PX300 original equipment charger in the EC651, whilst it has 3 phase charging, it does not have an absorption phase. I simply want to substitute a lead acid battery with something better without having to replace any of the charging equipment.
If It means the battery is charged to 95% and not fully but it has a deeper discharge then that’s good enough for me. Unless of course the battery is killed off in no time as a result. 500-700 cycles with Lead Carbon seems a reasonable expectation and if I loose 100 of these then again it’s not a show stopper.
The Sargent WIll have an absorption phase mate (on any non lithium setting) it may be called something else by Sargent though.
Merl
Super!I think what I will do is run my Motorhome on the Lead Carbon batteries for a day with no charging and the usual loads; then switch to run it on the Lithium, again with no charging and the same usual loads, then recharge each one in turn and see what happens as a like-for-like comparison of the Ahs taken out* and the time to recharge.
This will give a real-life picture of how the two technologies compare on an indentical setup.
*you might think the Ahs out will be the same but they won't in fact due to the voltage differences. The WATT-Hours may be the same, but the AMP-Hours will be different.
(I thought I posted this message this morning. Anyway, at 11:00 I stopped all charging and prevented the Lithium from reconnecting, so running solely on Lead Carbon now until maybe 11:00 tomorrow (might go for longer, might not).
You really should be whispering this sort of post mate, David will be along in a while and he'll give you a right ticking off!Hi.
Whether there is such a thing as a drop in lithium officially I don’t know, but I substituted the 2 original batteries on my Rapido 4 years ago for 1 Relion 100ah battery without making any changes at all, apart from altering the Victron BM settings.
I am absolutely delighted with the result and had no problems.
I have lived in the van permanently as well for the past 18 months totally off grid!!
Best thing I ever did.
