Jacking up your vehicle
All wheels should be removed annually when the vehicle is serviced.
If they haven't been taken off in 5 years someone hasn't been doing the servicing correctly ...
. :mad1::mad1: I totally agree with your comment especially on alloys the last time my van was serviced I specifically asked for the wheels to be removed cleaned and greased.they said it was a struggle to get them of and charge me £50 ,in my opinion for doing what they used to do and should do on service .I have first hand experience removing wheels that have been on for years .I don't think any mechanic would treat his own car like that .:mad1::mad1::mad1:
£50 to remove the wheels? how much to empty the ashtray?
Seriously, I would find another garage if you are using them on a regular basis and they do that!
My VW T5 had a problem with "holding onto" the wheels - slightly oversized hub I think as same with both steel and alloy wheel sets. last time I took the steel wheels off to fit the alloys, the two fronts refused to budge despite some persuading with my large rubber mallet.
Drove to local tyre place where they have bigger mallets wielded by bigger and fitter people than me and it took them 20 minutes to remove the front wheel. They then swapped the two fronts for the alloys for me. Total cost .... £0.00
Where did I do next time I needed tyres fitting? Where would I NOT go for a service?
Just my opinion but I dont agree.
You should remove wheels and rotate plus light grease back where they touch hubs,also do the stud threads,when of do a vis inspection on b/pads & condition of hoses pipes etc,in law YOU are responsible to make sure vh is ready for the road not some garage ,i do a daily walk round,bulbs tyres general roadworthy condition,old army training.
Wd 40 round the hubs the night before,they will come of easy next day.
No they wouldn't Trev. Sometime wheels stick on when the mating surfaces kind of chemically "weld" together (not literally, but by way of explaining the effect) and sometimes they stick on due to mechanical issues. The T5 issue was mechanical locking, not chemical.
And you think a spray of WD40 would do what 30 minutes plus of very heavy work with a mallet failed to? they must make it strong stuff in Ireland ;)
Just a quick word of advise for those of us lucky enough to own a vehicle with electric power steering.
It can be damaged by striking a wheel to remove it or, striking a steering arm to remove a ball joint.
Pullers should be used on these vehicles!!
I have a girder puller for my wheels that'll pull flywheels up to 2ft wide, I do struggle to get it on a ball joint though:hammer::lol-049::lol-049:
Also if using any grease on wheel nuts/bolts, make sure you only grease the thread & not the actual mating surface of the nuts, if grease gets on this then there's a good chance that they'll be over torqued as torque depends on friction!
Phill
Ps., I carry a 2 ton swivel handled jack made by SGS engineering in Derbyshire It's very well made, well so far anyway, plus a couple of wooden blocks, a 3/4" sliding t bar etc.,
I watch when my tyres are being replaced and make them know it.The one I use uses a torque wrench.I carry a 2 ton trolley jack,lumps of wood and a spider wrench and know it will do the job as I check regurlarly.
I have the renault master with the spare in the cage .I lowered it and greased the threads,also cleaned up the road dirt and checked the pressure within the last 6 months.
My brother was caught out in France a couple years back with a puncture on the motorway.You have to call out and pay the french breakdown mechanic.He claimed the cost of this on his breakdown insurance.
From what I understand it's illegal to do it yourself on an Autoroute.
True of course if there stuck that bad,but some times it helps esp with alloy wheels,hence i grease the back.
A lot of people swear by Coppaslip and its clones but that can make things worse in fact on many occasions, especially when a wheel has got really hot. I use a product called Ceratec, which is a non-metal lubricant, on the mating surfaces between wheel back and hub to (usually!) make sure the wheel does not stick on.
On the T5, I took the wheels off very soon after I first bought it and had the same problem back then - stuck hard - and I cleaned up all around the hubs with a dremal wheel to smooth it and it made it easier for a while but the problem obviously returned.
(I have had to deal with quite a few stuck wheels in the past as used to refurb wheels so I was removing and refitting wheels on a daily basis, but my own T5 ones were the worst I've had - and the Tyre place hadn't seen many worse either I think)
As well as the vehicle Jack ( which on a T5 is an excellent Jack ) a 6 ton hydraulic Jack an assortment of wood blocks ( useful for aiding levelling ramps )
Also a 4 ton air bag. We tend to wonder the North Yorkshire Moors and Scottish Highlands a lot of these places you get no mobile signal so you are on your own.
Whenever I have had the vehicle in the garage on returning home I always remove my wheels myself and retorque and do this on a regular basis to ensure they will come off when needed.
On previous vehicles with alloys I have always made a brown paper gasket to fit between the hub and alloy wheel. I have yet to do this on the T5.
Alf
Having trucked through France for years my understanding is that you can do it yourself, but if you need a breakdown service, you must use the French system
No longer the case Graham, you are correct originally stretches of autoroutes franchised with exclusive rights and extortion ensued.
The AA challenged in the courts and won , indeed patrols in France AA liveried vans RHD with British patrolmen, I know this is true because they were billeted in our accommodation .
I was based in Frejus as were they, however their patch reached the Ardeche so one can only imagine response times.
Both the lads seemed knowledgeable, I don't think the AA were short of volunteers ! Some recoveries were still to a garage but they had a better angle on ensuring customers and themselves weren't fleeced
Channa
Thanks Andrew, so can we take it, that if anybody has a problem anywhere on a French Autoroute, they can call by their own mobile phone?
The call out system to my knowledge didn't change you ring the number and operatives summoned the lads were possible. From a customers perspective a chance an English speaking mechanic at the roadside. From the AA standpoint they broke the monopoly of the old system and their liability dropped in charges of recovery, it also helped the customers that spurious work was avoided. I wonder how the B word will affect things.
channa
Definitly a case of be prepared when it comes to punctures,yesterday I decided to take a worn tyre off,my three foot breaker bar was flexing a lot with no sign of any of the wheel bolts moving.Showing the breaker to the garage who was going to fit the tire they said if that cant undo them neither can they,I returned to have another go and broke the knuckle on the breaker bar.I then went to comercial vehicle garage who also had difficulty,after then clouting each bolt five times with heavy lump hammer and 1" type of dolly bar the bolts yielded to a breaker bar.I will now be carrying those extra tools just in case.The wheel was correctly torqued up about five years ago but time has had an effect on it I think.
So rather than follow manufacturer's service guidelines and remove the wheels annually it is better to break equipment and risk injury ...
I learned recently that re-torquing wheel nuts can either be done after driving 30 miles or thereabouts, or after the vehicle has been standing for 30 minutes.
The second option is probably easier in my view.
Coppaslip should not be used on alloy wheels its for the back of brake pads which do get very hot but would be ok on steel wheels,a water proof non fling grease 2 4 C marine prop grease will do ok and can be bought in a small tube.
As well as the vehicle Jack ( which on a T5 is an excellent Jack ) a 6 ton hydrate Jack an assortment of wood blocks ( useful for aiding levelling ramps )
Alf
May get soggy unless grease prof paper leaving a slack wheel 2 4 C marine grease alf
