witzend
utubeThank you , that's really useful.
What is YT?
What is YT?
Oh, and after you remove the Airbag, treat it like a UXB - as that is what it is with its self-contained detonator and explosive charge!.... Super-Easy to remove the airbag! (make sure no power to vehicle when doing this. Disconnect the battery first and don't connect again before airbag refitted or you will get the warning light on).
YouTube...utube
You TubeWhat is YT?
Not nice to call folks names.You Tube
no changes of any sort.Have you recently changed any bulbs with LED's? as this would cause an error with the CANBUS system.
Thanks for that . have replaced the bulbs . = no change. Have run extra earth leads = no change. Will try your voltmeter suggestion just inNormally switches fail because they dont MAKE a contact due to dirt or corrosion etc, your symptoms suggest that a connection is being made when it shouldn't be ie you've got a short somewhere so to me it seems an odd fault to occur at the control stick? but then again those sticks are packed with connections so maybe perhaps??
I remember a similar perplexing fault that a friend had many years ago and that was caused by the 2 filaments in his stop and tail light touching inside the bulb envelope. Maybe worth taking a look if you've got dual bulbs.
I agree with most, it sounds like a bad earth fault. As Steve has suggested you really need to check the earths under load, the easiest way of doing this is rather than measuring resistance/continuity between points with an ohms setting you ,measure for volts between the same 2 points under load. Clip one multimeter lead to a good earth/chassis point and then check all the other points that should be earthed with the other lead with the meter set on low DC volts (2V) while you try all of the different lights. You should only read quite low voltages depending on the length of vehicle earth wiring and would typically be in the millivolt range, if the meter goes higher or 'over range' ie more than 2v then certainly investigate.
HaveAfter having a similar problem on my work van I discovered that the connection block to the rear light group was slightly corroded causing a poor connection via the earth connection. Have also experienced this problem on a previous van where the connector block attached to the circuit board within the light cluster gave a poor earth connection. A quick rub with light abrasive followed by some spray silicone fixed it each time!
WOW!Certainly worthwhile exploring other options before disassembling too much to swap parts.
I had the "known design fault" with my heater direction control on my VW T5 (VW fitted a stranded cable instead of a solid cable and they always bent). In the process of trying to route the replacement cable I managed to just break a tiny bit of the mouding the cable end ball popped onto
heater flap lever by David, on Flickr
Fixed the flap lever - The screw replaced the broken-off bitand saved buying a new part - worked perfectly
But to access this little part to repair involved a minor teardown at the front ....
T5 Dash by David, on Flickr
Have you plugged in an EOBD reader? That could help with the diagnosis? might need a vehicle specific one for best results but they can be quite revealing even down to individual switches.Many thanks to all who have contributed so far. I am still working on it and have tried all of the suggestions. Next move is to check/remake all plug ins to the body control module if that doesn't work will be taking it to the local Auto electrician.
I don't have a reader but hope the local auto electrician can help with that. Time to call in the experts.Have you plugged in an EOBD reader? That could help with the diagnosis? might need a vehicle specific one for best results but they can be quite revealing even down to individual switches.
This explains why changing the heater servos on my Mercedes took 4 1/2 hours, at a main dealer where they knew what they are doing. All because they changed from using levers and solid wire cables to electronic switches, microprocessors and servo geared motors. Somebody somewhere thought it would be a good salesroom gimmick.Certainly worthwhile exploring other options before disassembling too much to swap parts.
Looks like that tops WD-40 as a ‘cure all’!
tastes pretty good too !Looks like that tops WD-40 as a ‘cure all’!![]()
