Fisherman
Could be a faulty breaker switch in distribution box.Yes. That was the first thing I did. K
Thank you. Is this something I could check / look at? If so how.Could be a faulty breaker switch in distribution box.
So I'd say the problem will lie with the automatic change over relay or it's wiring.The system is set up so that it thinks it is on EHU whenever the inverter is switched on.
'The system is set up so that it thinks it is on EHU whenever the inverter is switched on.'// Yep Julian, the OP already said//
If the van works OK on EHU then you could perform a workaround by connecting the EHU lead to the vans external socket as usual and then plug your EHU lead into the inverter.
Post #18........ hopefully the OP didn't leave their 13A adaptor at home![]()
Got fed up reading well before post 18Post #18
It looks like a Edecoa model Julian, I have one and there's no UPS built in and I've had to add my own auto change over. Anyways...as has been pointed out above the OP had actually plugged his EHU into the inverter and it worked fine so it's deffo a fault with whatever's doing the change over or the wiring there of. He may have a auto transfer switch/breaker in his CU?'The system is set up so that it thinks it is on EHU whenever the inverter is switched on.'
Ah the semantics fooled me, but now I've re-read it. Almost certainly the switch over relay/contactor failure. But is that incorporated in the inverter itself as is common now (but it looks an older model) or sperate stand alone
bit daft trying to give advice then, isn't it.Got fed up reading well before post 18![]()
Done the same thing accidentally myself Davidbit daft trying to give advice then, isn't it.
sorry, your comment was no doubt meant to amuse, but it didn't.
Wellll, life's pretty daft and pointless anyway don't ya think? I mean what's it all for?? We're all going to die at some point anyway so why bother with anything eh? But the post DID give you the opportunity to have a bash so.....dip you're bread in big fella.bit daft trying to give advice then, isn't it.
And? Did it offend you?sorry, your comment was no doubt meant to amuse, but it didn't.
No haven’t one of those. And the cable out the top, which feeds the 220v disappears down inside the panels to below the inverter. So I wouldn’t be able to access it very far.Generally speaking, the physical cables themselves rarely go wrong so the problem will most likely be with the plug that goes into the inverter (probably a standard 13A UK Plug or maybe a European Schuko plug, depending on where the inverter was bought) or the socket at the other end where it is connected to whatever distribution setup you have.
Something that could be useful is an NCV - Non Contact Voltage - Tester. As the name suggests, you test for a voltage without needing to make contact with a bare wire so is very safe for anyone to use, and so you could say place this by the socket and check it if beeps. Then plug in the plug and place the tester against the cable a few inches away and see if it beeps. You can run the tester along the cable where you can get access and see if you get beeping or not. This might help determine at what position the power is not getting through?
Not foolproof as if you have an active live and a ground in the cable you will get a beep so it won't find a problem with Neutral but as an initial check I think it could be useful and something to have in the van anyway so is an investment.
This is an example from Amazon Turkey ... https://www.amazon.com.tr/Sayımları-Aydınlatmalı-Kapasitans-Süreklilik-Otomatik/dp/B0D13DDZ1B/ref=sr_1_42
Not sure how much 750 Turkish Lire is, but in the UK these are around £15.
You can also use these on breakers but have to watch for false positives with so many wires in a box that might be radiating power to a tester (set to high sensitivity to try and eliminate that).
But thank you anyway David.
Georgia sounds like a real adventure. I had to search the map !Thank you all … so I’ve a work around with an extension cable inside from the inverter to my table. Just means my kitchen gadgets have to go on the table. I haven’t the tools or the skills to check what is going on between the inverter and the 220 system. And I might break a nail! It doesn’t sound like a repair a novice could do. If you hadn’t guessed from this … I’m female! Lol
About to head into Georgia. No repairers there but found a hire company who may have a contact who could look at it. Otherwise, it will have to wait until I bring the MH to the UK.
Thanks again
Katherine
