alwaysared
Yes it is and I have the same type of thing for my Philips Sonicare so that's the two main brands coveredHere is mine charging in my motorhome usb socket, is this an inductive unit ?
Regards,
Del
'Home' and 'van' are the same thingLeave it at home and buy a usb one for the van.![]()
Those USB chargers don't convert back to 240v, they just use 5v and therefore take a little longer to charge the toothbrush from flat but I just leave mine on so it never gets too low.Ok thanks. I could get usb chargers for our toothbrushes but will probably continue to use my inverter. How much more efficient is it to convert 12V to 5V than to 230V?
They must put some sort of sine wave or rapid switching into the coil current otherwise there would be no induction.Those USB chargers don't convert back to 240v, they just use 5v and therefore take a little longer to charge the toothbrush from flat but I just leave mine on so it never gets too low.
Regards,
Del
Lovely to read such arrant nonsense. Of course it bloody well works. I'd not recommend it otherwise.A usb charger will not help. It is a sealed unit and charges from it’s own sealed mains powered base. I think the base charges via a mains powered induction coil.
Modern Oral B toothbrushes have li-ion batteries. Much, much better. Probably better battery life than your Lidl one.The same applies to inductive charging pads for mobile phones etc. Usually very poorly made if bought as an add-on.
An Oral B toothbrush typically uses a single NiMh cell inside, AA size, 1.2V nominal. The inductive charging circuit is decent with flashy LEDs to keep you informed. You can take them apart quite easily and put in a new cell, but by then they are probably wearing out elsewhere. My cheapo Lidl job has twice the capacity and will go in the Wee when it dies.
I was not aware of a USB charger for my Li-Ion tooth brush when I made that post, I thought you were referring to a different type. I then learnt something and a few posts later acknowledged that and said thanks. I thought that was the point of forums, sometimes you learn something. There are politer ways of pointing out a mistake.Lovely to read such arrant nonsense. Of course it bloody well works. If not recommend it otherwise.
The USB powered charger base works exactly the same way as the mains powered one. The only difference is that it only costs £4.99
If I post something that is wrong, when I realise my mistake, I correct it. Why didn't you?I was not aware of a USB charger for my Li-Ion tooth brush when I made that post, I thought you were referring to a different type. I then learnt something and a few posts later acknowledged that and said thanks. I thought that was the point of forums, sometimes you learn something. There are politer ways of pointing out a mistake.
The conversion from 12v to 230v to just power a toothbrush charger is about 0.1% efficient. The conversion from 12v to 5v is about 99.5% efficient.Ok thanks. I could get usb chargers for our toothbrushes but will probably continue to use my inverter. How much more efficient is it to convert 12V to 5V than to 230V?
What is the current used when it is switched on but with no load?Ok so ended up getting a Green cell Pro 300W pure sine thing, cost 50 quid all in. Will report back on whether it's any good...
I thought I had.If I post something that is wrong, when I realise my mistake, I correct it. Why didn't you?
