Fazerloz
Our coffee unit give batteries a hard life. The battery when new will easily work a 10 hour day. Depending on the make of battery they will last from as little as 6 weeks up to what we use now Trojans 12mnths. When knackered and only lasting 4hrs the volt meter will be reading 12.5v and when put under load will drop into the low 10s which would be below your fridge requirements causing it to fault. When taken off load the battery voltage rapidly returns back to 12.5/12.4v which would make you think the battery was good. But it can't supply required amount of power.
Do not forget with a 110ah battery you will only in reality have a usable 60/70ah without doing damage dependant on the quality of the battery. If so you are doing well to get your 5 days without ehu.
At this moment I am having the same problem with the comp fridge in the MH as you and for some reason I am back peddling from buying new batteries when I know it would sort it. Suppose it could have something to do with spending £400 on new batteries.
