marchie
WoW, it does all that and they don't even bother to fit one, though they make themHeat rises fitting a full size under tray improves engine cooling. Also most cars use them to protect the engine from road debris, to lower road noise, and to improve drag the coefficient which results in better fuel efficiency.
I found this online
Yes, an undertray can significantly impact engine cooling by directing airflow and creating a necessary low-pressure area under the car to draw hot air out of the engine bay. Without the undertray, the airflow pattern changes, potentially trapping hot air and hindering the radiator's ability to cool the engine, though some argue the effect is minimal.
How undertrays affect engine cooling
Consequences of removing an undertray
- Directs airflow:
The undertray channels air through the radiator and other engine bay components, rather than letting it escape chaotically.
- Creates low pressure:
By creating a sealed or semi-sealed space under the engine, the undertray encourages a low-pressure area beneath the car, which helps to suck hot air out of the engine bay and away from the radiator.
- Improves radiator efficiency:
The increased pressure difference across the radiator, thanks to the undertray, forces air through the radiator fins, improving its ability to dissipate engine heat.
When it might be acceptable to drive without one
- Reduced cooling:
The primary risk is the loss of this controlled airflow, which can lead to heat buildup in the engine bay and potentially affect engine performance.
- Aerodynamic changes:
Removing the tray can also alter the car's aerodynamics, creating unwanted lift and drag, which can impact fuel economy and stability.
- Component protection:
Undertrays also serve to protect sensitive components like the oil pan and transmission from road debris, water, and other hazards.
In summary, while some may drive without an undertray without issues, it generally plays a crucial role in proper engine bay cooling and should be replaced if damaged.
- Temporary or specific conditions:
Some argue that a short-term absence of an undertray is fine, especially in good weather conditions and on clean roads, particularly for a weekend car.
- Aftermarket modifications:
If you have an aftermarket radiator or other cooling system upgrades, the impact of removing a stock undertray might be lessened, though this isn't a guarantee.
