Moonraker 2
Just had a reply from another recommendation who said, No they don't fit heaters. Going to give up now.
The only part that might need changing on D2 / D4 models as long as filters don't get clogged up is what they call a plug strainer, this is an easy job to do as long as access to the top of the heater is ok, the glow pin has to be removed and the plug strainer is located in the bottom of the hole simply hook it out and replace with a new one, you'll know if it needs changing as the heater will smoke quite badly on start up or even fail to establish a flame and then shut down. the most problems I have with the ambulances is overheating mainly due to staff blocking up either one of the warm air inlet/ outlets with a bag or something. Also worth checking the air inlet on the heater for a build up of fluff / hair etc as this could also cause the heater to overheat .I was looking at some data sheets on the Eberspacher site earlier in the week and they state that once fitted you don’t need to touch them. All it says if not used then you should run it once a month. I know mine hasn’t been touched in the 22 months I have had my van and all seems good.
What is the maintenance they need and when?
Start up and shut down is controlled by electrickery, and must be completed under full control. If e.g. your battery runs flat and whatever system you have just cuts the power, or trips the low voltage cutoff of the heater controller, then there is the possibility that the burner and even exhaust pipe, if incorrectly routed, could fill with diesel with various dire consequences if the shut-down sequence from the controller is interrupted.
Actually there is some pressure between pump and burner. That's why they need the proper rigid tube in the shortest run. As the solenoid pump moves back bubbles form in the diesel under vacuum. From air, water but mostly volatile hydrocarbons present in the fuel. As it moves forward this gets compressed again but not fully re-absorbed. Hence the need for the pump to be mounted near vertical so that the burner remains fed with fuel, and the gas bubbles can rise up and flow through, rather than causing a vapour lock.
The entrained gas bubbles keep the fuel squirting into the burner after the pump has been stopped. Maybe not a lot, but fuel does continue to flow after the pump stops.
The controller knows about this and the startup sequence includes pump priming steps to try to minimise this. If you run out of fuel then have to re purge the system it can be slow or just impossible if the fuel run or pump installation is incorrect.
As far as I am aware there is no pressure in the fuel pipe from pump to heater the pump is a solenoid pump and is always fitted below the heater when stopped there is no pulse so fuel stopped no pressure, admitted the shutdown is not completed which is mainly to cool the hot heater down.
The controller knows about this and the startup sequence includes pump priming steps to try to minimise this. When correctly shut down the line from the pump to the burner should be devoid of most fuel, so start up requires it to be re filled
I have a Hydronic that is mounted below the passenger headlight in the engine compartment and a D4 mounted at inner floor level under the bed. The D4 was professionally fitted by a previous owner (I have retired receipts) but pump sounds like it is in the engine compartment maybe 5 metres away.
The D4 has never failed due to low voltage but will fail if diesel level gets too low.
