camping_gaz
looks mint be glad when i get another van i will be doing the same
Lenny
Carpet much more comfortable than hard flooring.Why not cushionfloor the van and then have a fitted removable carpet for colder periods? Cheap offcuts from discount places does ok.
I love to wriggle the tootsies in a long pile carpet!
Mind I don't usually have to clean it.
weez
tony
Carpet is great until it gets wet; then it is B. unpleasant and stinks to high Heaven. I've just had 10L of water through the van and it took some hard work by 2 dehumidifiers to clear it. The carpet now looks B. awful and has water stains all over it. I will never use carpet again.
I have also tried Flotex & it is very good. It it is terribly expensive but, obviously, you don't need much to "carpet" a van.
The best floor covering that I have seen to date is the stuff that Nomad has down in his Iveco. It is some form of "rubber" tile that is intended for workshop use. It seems both durable and warm under foot. Good stuff, maybe a PM to Nomad may get you an answer?
Lenny, why not have the best of both worlds??? Our van has fitted lino, then a loosely fitted carpet on top, any large carpet store can get your new carpet whipped - edges bound, then you have lino for wet weather or when staying on sandy spots, then you fit the carpet for winter use.
It REALLY is a lot nicer/warmer having carpet under foot. I added some press studs to the corners as the Chausson carpet would slip 'n' slide a bit if you jumped into the van a bit quick!
I have used the flotex in cutom vans very good hard wearing and easy to clean.
I can believe that: British carpet-baggers have a bad name in France.... we always take the carpet out when going to france.
Thinking about removing the 17 year old carpet from my van and replacing it with a cushionfloor type vinyl
Has anyone done this or can anyone advise on the pro,s and con,s of of this action?.
