Asterix
Just picked them up from Bimble,now just have to figure out how to attach them to the roof! They are heavier than standard solar panels so something to be aware of if considering them.
All solar panels are more or less the same efficiency: between 18.5% and 20.5% generally.
If putting a shiny surface underneath would make a worthwhile difference, don't you think the makers would have done that already?
If you don't want tilting panels (and I don't blame you) you might think about a reflector that would bounce some sunlight onto the horizontal panels.
oh no you have not,it is yours so keep asking, keep going dont rush, ok pj.Sounds like a good idea but on the average motorhome panel mounts the panel is quite close to the roof so is it going to get much light to the underside? I think not. Maybe Ive picked the idea up wrong?
my solar has only the white body under it,p.s. works .ok.pjPerc is a totally different technology to the OP. Bifacial panels (as the name suggests) rely on light hitting both sides of the panel.
my solar p ,on little legs,on to roof,see what you like,ok pj p.s in nottinghamBefore I mounted them I was going to lay foil on the roof,I got up there and laid down a sheet and was immediately fried from the reflection,I decided that could be a really bad move so ended up painting it white as per manufacturer recommendation. I had been considering some sort of reflector but decided if I'm going down that route I might as well tilt the panels,which I don't really want to do.
That doesn't accord with my understanding of the facts. Do you have a source for that research?I’ve been shopping around for solar on my house and found unless you’re limited in roof space it isn’t financially worth paying the extra for premium panels, but on a motorhome where you’re quite limited, it may well be worth it. Better panels produce more from the same area and also degrade at a slower rate. Top grade will degrade 0.2% per year, the worst at more like 0.7%. The cheap ones used on motorhomes may well be worse than that as it’s not a spec they give out.
