n brown
I spent some time installing domestic PV panels on roofs (just before 'the man' killed the only growth industry during the post banker dip we're enjoying...but I digress).
These were fitted over November and into February and were producing higher ampage per hour than they did in the summer, the angle of the sun is better (on a sloped roof) in the winter and the radiation levels are often higher for PV generation in winter. In the summer less per hour is produced but there are longer days and clearer sky and so overall the production is higher.
why not just get a folding oneI must admit at the moment I'm thinking whether I can get a semi flexible panel that I can affix to the van with strong magnets so I can move it around various sides to follow the sun ( I have enough storage space to keep it safe in the garage) and then I can try and get maximum sunshine rather than best effort if it was on the roof.
Not many have your setup though, and obviously works well for you. I wonder how many are disappointed with their setups i am sure some must be.
Those panels do look like they could be a good buy.
About a year ago I fitted a 100w panel and controller. Been working fine but the last few days I've noticed that there doesn't seem to be much of a charge going into the batteries ( 2 x 110). Today I'm in the South of France in blistering sunshine and my BM1 battery monitor tells me I'm feeding 0.5a to the batteries. They are at 13.5v and at 89% capacity. Checked all connections. Panel is clean and not shaded. Solar charge controller is flashing slowly indicating that it is charging batteries. I'm stumped.
Pat
You may have only required 20% of the panels rated output. The panel may have only been producing at 50% of rated output, due to deterioration of the panel but still plenty for your needs. But the panel is operating at 50% less than rated output so not working efficiently. Yes you do know how to push a button and it would say everything was ok but would not be a indication of panel efficiency. Oh and batteries can explode. :have fun:
Yes I will, but the unit has MC4 connectors. Do I just buy another pair of male/female connectors or do I need something special? I'll be using a Schaudt solar controller.
John
Your Schaudt regulator will come with a number wiring sections. If you have an EBL, there will be a fitting to put in line with the EBL charging output. This is for the solar panel to also charge your van battery.
There will be a lead to plug in to your EBL solar socket, the other end plugs into the regulator. BE CAREFUL ABOUT THE ORDER IN WHICH YOU CONNECT. The solar connection on the EBL has voltage on it, so connect to the regulator BEFORE you plug in to the EBL as the two ends on this lead are not insulated and you will likely blow the solar fuse on the EBL (like I did).![]()
heres a 100wt panel.SPECIAL Best Seller OFFER! 12v 100W Solar PV Panel Mono Caravans Boats Motorhome | eBay
i agree how can anyone compete with prices like that. every camper van should buy three.
mind i do like gas lights . light heat and keep mozzies at bay.
would i need to double these up to charge my 24 volt system or simply buy a 24 volt regulator
