Out of curiosity I decided to see what I can stuff under a Ducato seat
Now a few notes first ...
1) Not making any connections to the battery - that can impact what will fit (last week I had to rout out woodwork under a seat to make room for the battery bolts and cables as it sat around 6mm too tall, for example)
2) There is nothing under the seat that is causing any obstructions (apart from note 3) so I could slide the batteries physically in and out
3) My 'testbed' is an Autotrail Motorhome - this has a raised floor directly behind the rear of the seat base and is a physical stop to how far the battery can go back - a PVC will have more flexibility I believe - and this can be important and even critical.
4) Batteries tried are not recommended in any way - Just using them for their physical size.
First I tried a Leoch Adventurer AGM - this is a 120AH (C100)/97AH (C20) battery and being AGM can be laid on its side.
It is just 300mm long but is 220mm tall. Too tall to sit upright, but on its side it will slide in long-ways into the seatbase
There is plenty of space in front. In fact, I could slide another one in front of it and only be around 1" shy of being able to close the front base cover
I think if I tried this on a Ducato PVC, the rear battery would have gone back further and I could have closed that cover. The way the front and rear covers are shaped on Ducatos, I also reckon cabling would not be an issue - rear battery with terminals to rear; front battery with terminals to front.
The Batteries.
I then tried a basic Lead Acid battery - an 'Enforcer Leisure'. This is a typical low-cost battery fitted in campers and motorhomes, got a vent tube so probably a wet battery and not one you would put on its side!
It is labelled as a E110-LOW - so a 110AH (at C100 I would think) and low height. Taking measurements, it is 180mm tall, 175mm wide and is 350mm long - so it is 20mm longer than the typical G19 battery.
This is too long to fit across the width of the seat base, but is low enough to clear the seat base top and also the 350mm length is no obstable to it going in lengthways, even on the Autotrail with raised floor.
Looks to me like as long as the battery has dimensions of no more than 300mm x 360mm x 180mm, it will fit in the -
empty - seat base of a Ducato
