Another battery thread
We have 3 proper batteries that do everything that we need connected to a 120 solar panel and the 3 of them probably cost less than one of these new fangled ones !!
The latest prices for Lithium batteries have them at the same price ,or less, per usable Ah, than LA/AGM. Add in a much greater expected lifespan, and if the vans a keeper it makes a lot of sense changing to Lithium.
Van isn't a keeper though...plan for one more year only. 😔
Anyone had dealings with the battery store...have found a couple of batteries which would fit.,.one lithium also and seems reasonable prices...which worries me! https://batterystore.co.uk/uplus-12...lfp12100-deep-cycle-for-solar-rv-marine-more/
It's not unusual to see 100ah lithium at £150-£200 so nothing to be suspicious about. You would really need to buy and install a B2B with lithium though as I mentioned before so you need to consider the additional outlay going into a van that you don't intend to keep.
Would you get an extra couple of hundred quid or so if the van had a lithium battery and B2,B already installed?
If no then just buy the largest AGM you can get in and hammer it hard this season without considering how far you're discharging it and pass the lithium or not dilemma onto the new owner.
IF you think you could get the additional costs back (I doubt it but I'm not sales ex spurt) then maybe go for it.
Would REC not also need a change of 240v charger as well with a lithium profile. I think he said it was a 2018 van so maybe it already has one. Not sure about the MPPT controller.
Not necessarily, I know of someone who initially installed a 100Ah Lithium in a older van with no extra equipment, I think they used Gel settings on charger, after a year of use they installed a B2B and added a specific Lithium charger to get the most out of set up. Although I think he said the maximum charge rate of battery was 50a, never seen one with that, so might have been a BMS that is user adjustable?
Yep. I know there are accounts of people doing that or just dropping them in and fudging settings but for me personally having spent a year reading up on it, watching various videos from the likes of Victron and Off Grid solutions who of course want to sell you all their products it seemed like a risk not worth taking to me to cut corners and especially if its (in my case) a field where I am not an expert and are counting on the advice of others.
Too many variables involved for something to go wrong. Either do the job properly with all the right kit or don't do it at all. Its how I've worked in IT for decades and this is kind of the same thing IMO.
  • Like
Reactions: REC
Thanks all...spoke briefly to the man that did our conversion ( now living off grid in Ireland) ....he agrees b2b and as you say, not worth messing around with if planning to sell. . Apparently the mppt has a lithium switch so wouldn't be an issue with that..but not an issue if we get an ordinary leisure battery. Found one which looks like it will fit
Not much more than 90ah but can be discharged more (if I read it right!)
The charger is a numax...this one I think...will I have to get that changed or will it be ok for the above battery?
I asked ChatGTP for you. :D Obviously this is AI but so far I have found it spot on.
"will a numax battery charger model 12100 charge an AGM leisure battery properly. I know some standard 240v chargers will not charge an AGM battery to its full capacity so want to know if this one will"
ChatGPT said:​
Good question — you're right to check carefully because AGM (Absorbent Glass Mat) batteries do need a proper charging profile to reach full charge without damaging them.
The Numax 12100 is actually a smart charger (also branded sometimes as a Numax 12A 12V charger/maintainer), and it's designed for both standard lead-acid and AGM batteries. It provides a multi-stage charging process, including:
  • Bulk charge
  • Absorption
  • Float/maintenance mode
Importantly:
The Numax 12100 will charge an AGM battery properly because it can reach the slightly higher voltage that AGM batteries need during the absorption phase (around 14.4–14.7V depending on the exact battery spec), and then it drops to a safe float voltage (~13.6V), preventing overcharge.
A few things to double-check:​
  • Make sure the battery size (Ah rating) is appropriate for the charger's 12A output. For example, if your AGM leisure battery is something like 70–120Ah, the 12100 is a good fit.
  • Confirm that your specific AGM battery doesn't require a specialized “AGM+” setting (some newer AGM types want even slightly different profiles, but this is rare unless it's a very high-end battery).
Summary:
✅ The Numax 12100 will safely and properly charge a typical AGM leisure battery.
✅ It won't undercharge it like some old-fashioned basic chargers would.
When I first fitted my lifepo4 I used gel setting on my mains charger, changed y solar controller to lithium and had the factory fitted split charge relay. Ran like that for over a year, if I was on eau I would turn off mans charger if it got to float.
Batteries are 6 year old now and still perform as the day I got them.
People confuse what you can do with what is ideal a lot I think.
If I was looking today I would just get the cheap eco-worthy batteries. Everyone has to make up their own minds though, its their cash
Ordering the
Only good if they have the size though...tried them first :confused:
remember that you have the potential of laying a battery on its side quite possibly?
If you are looking at battery sizes and eliminating any that are overheight, you will get a very small choice.
As an example, VW Transporter batteries to fit under a cab seat meant you were limited to around 100Ah - but if fitting on their side, you could get upto 160Ah ones to go in - and the Transporter bases were very small compared a fiat ducato type seat. base.
As an aside, I fitted a B2B to a Ducato and the owner had a pair of lead acid 100Ah batteries under the drivers seat. It was a very tight squeeze and they had to be low-height ones as they are next to each other but it was done.
I can't recall what batteries they were in that ducato but I used to fit the Leoch XR1750 Battery under the Transporter Cab seats - https://www.alpha-batteries.co.uk/12v-xtreme-110ah-agm-leisure-battery-xr1750/ . These are good batteries, but maybe a bit dated and pricey compared to newer options, but in terms of low height batteries, they are a decent option.
To OP, what is the make of your van? If it's a Ducato then the 190 high one David shows should be a good height, and the length would normally be OK as well, the ones you are linking to are a bit tall and would be best on side if they can be.
