if you hae room,these are great . an example https://www.ebay.co.uk/itm/Carver-S...170106?hash=item56e65ef47a:g:ZsYAAOSwsMZfX76eHave you room for the old type through the floor gas heater which is safe and requires no lecy.
Modern diesel heater gets my vote, 2kw plenty big enough for a small van. Cheap to buy & low power usage. Dry heat too unlike some gas heaters...
Yes, they have the same fans as diesel heaters. They use around half as much 12v power overall as the LPG equivalent. This is simple fact.well ,LPG heaters need power for their fans, unless it's a carver type
jolly good . anyway ,as i said ,my recommendation would be a floor vented carver , morco or similar as they use no power at all and have no moving parts to go wrong . the output of 1800w is comparable to a larger eberspacher or webasto . in one van i had a webasto 3500 and a morco 1800 , and they both took about the same time to heat the van interior , the only difference being the noise of the webby .
i actually prefer a woodburner
If you you use the old fashioned carver type gas heaters, but sure your floor is air tight. Carbon monoxide poisoning is not a good way to die.
same here ,we had woodburners in most of our living vans - great when you're skint ! but now , being able to flick a switch ,well , i expect you appreciate it as much as we do .After living with a woodburner for 10 plus years.... On a narrowboat.
I'd go diesel everytime now.... Either eber blown OR drip feed stove and back boiler.
Woodburner was cosy BUT dusty, smelly, temperamental, and prone to going out when most needed....
Decent fuel is also difficult to find for free now.
Thank you!if you hae room,these are great . an example https://www.ebay.co.uk/itm/Carver-S...170106?hash=item56e65ef47a:g:ZsYAAOSwsMZfX76e
Is that the Chinese ones?The cheap diesel heaters are amazing value and most owners are very happy with them ,they use a bit more electric but are a fraction of running cost even the smallest heater would overpower a romahome .they can run from the deisel tank ore a separate tank .a romahome can only carry a small amount of gas making it very expensive to run ,plus you can run on red diesel making it even cheaper .and much less chance of running out.
