Deleted member 16303
Please check that the devise works with refillable cylinders. Most side action ultra sonic ones get confused by the float that insures you can’t overfill. I have tried out models two that gave false readings.
over complicated wet water technique ? and the wallet is lighter than the gas !!.
The only way to measure something like is a float system!..As I mentioned most gauges work on Vapour pressure and the inherent variables that make it useless.from the Gaslow website:
Our new cylinder is fitted with a new mechanically accurate contents gauge.
I have lpg to run my car the gauge is a waste of space. As lpg is a liquid with a head of gas above it as you draw gas off more liquid turns to gas and this causes the pressure to remain the same. To get an accurate reading requires two readings to be taken, one from the liquid and one from the gas, these are then fed to a differential gauge for an accurate reading, (expensive). Same system as the hospital oxygen tanks.
My van tank is underslung and has a float in it but means grovelling on the floor.
We have a 2 x 11kg system, we were out at the weekend, checked the tank levels which were showing a quarter full, as we are going to France for 3 weeks shortly decided to fill up the tanks at our local ASDA. only got 10 litres in before the pump cut off. I checked the gauges and they showed just under half full. Have I got faulty gauges or do you think there could be a fault in the system. I posted last year that the tanks took an age to fill up. Cheers Andy
You have 2 cylinders same as my set-up.
Leave one cylinder closed and run of other cylinder. When gas stops change onto 2nd cylinder.
You then know its time to fill up empty cylinder.
Why bother with scales etc etc ? Unless i'm missing something, i stand to be corrected.
