ChrisInNotts
A modern Fridge (80l) / Freezer (12l) will use about 3kw per day on EHU and 300 g per day on gas.
This is about £1 a day at the prices being quoted.
2kw heating will use more in a couple of hours that the fridge uses each day.
Exactly your right.
And if you owned a CL or CS you would know how much the electrician charged you to install the electric hook-up points.
Some people would even charge up their electric motorbikes up overnight![]()
Exactly your right.
I was reading that too The who it doesn’t apply to para allows campsites to price independent of the energy price.Out of nothing better to do this piqued my interest, it seems it’s a little more convoluted than first thought.
See guidance here https://www.ofgem.gov.uk/ofgem-publications/74486/11782-resaleupdateoct05pdf
Typically, a three-way fridge uses about 200watts on mains power, but of course it is thermostatically controlled. My guess is max 2KWh per 24 hours, maybe less. If your batteries were low, add another 1KWh to 2KWh.Fan heater !
We have a small fan heater. 2KW or 1KW settings. Only ever use the 1KW together with it's thermostat.
In spring or summer it Switches off after 15mins or so ! So 1/4 unit..This 15min Burst may be repeated ever hour.
We also use a rice cooker maybe 800 watts fot 15 minutes maybe 2x .
Of course with EHU the fridge goes to Leccy and from what I read uses a significant amount
Yes, but it does depend on what you pay for your LPG. Refillable costs from 6p to 12p per KWh, but if you use small exchange bottles it could cost four times as much per KWh.LPG is usually cheaper than electricity on a Campsite.
Other way round. Always full power, not all the time.Fridges although lower power run all the time obviously not at full power.
You seem to think that either I do not understand or I have a problem with power.Other way round. Always full power, not all the time.
The thermostat turns the power off when the set temperature is reached.
Correct Rob , that law seems to have gone the same way as builders building affordable houses . Home Leccy is about 14 p a KWHNot sure what the usual rate for consumers is at the moment, but I thought the sites were not allowed to charge more than that?
