RichardHelen262
Did the second engine arrive ?
Grand scheme of things it is nothing
We may have had two weeks away in that time period.
Not booking the channel crossing for next summers Scandi-fest yet though.
How should I treat my "new" engine when I get it back?
Sofim 2.8idTD
Shortish period before first oil change?
Should I start using Shell V power diesel?
5 thu oil change or 6 mth which ever comes first for short hops,asda 10/40 or 5/40 is ok,i liked the tip on turbo cooling a new one for me must remember it.:bow::wave:
I fitted an oil temp gauge to my Saab 900 turbo.
Only time I ever saw it move was a rapid climb to 1500m in Switzerland.
you would be surprised how long the turbo still spins after you turned the engine off after a hard run. Engine off means no more fresh oil supply and the remaining little bit of oil in the bearings gets cooked. Letting the engine idle a few minutes can avoid damage. Fitting a oil temperature gauge is on my list.
Even if the water temp is looking ok, the oil could still be at the upper end of the working temperature. Especially on a chipped turbo diesel I want to know what the oil temperaturs are to back off the throttle when it get's critical. But luckily in the UK there is a motorway speed limit and there aren't too many steep hills causing too much stress.
Very true, always surprises me when people pull over to take pictures, look at view etc, while on a long climb, and immediately turn the engine off.
BTW, I'm no expert, but I have been told that exhaust gas temp gauges are the best way to check on turbo, may be worth looking into.
