Siimplyloco
It appears I missed your pic of the bowed bar you are in the process of manufacturing but I meant well
Good luck
Ian
No problem: we are of the same mind!
John
Good luck
Ian
John, you have let me down, I would have thought a man of your caliber would have sussed out the easy, alternative engineering route to the conundrum. No machining, no added weight.
Have Mrs John sit on scooter, one hand holding onto rear ladder to secure. The other benefit is, you don't get earache with Mrs John secured to rear of motorhome!!
Hmmmmmmmm, I should look at getting a scooter ....:raofl:
If Maggy was sat on the back I would still hear her, far better to sit her on the scooter then leave the scooter at homeHave Mrs John sit on scooter, one hand holding onto rear ladder to secure. The other benefit is, you don't get earache with Mrs John secured to rear of motorhome!!
I would look at fabbing up a "U" which then slides under A-frame device bolted to MH, alloy will wear in no time, unfortunately.
When I had my moto-x bike, I knocked up my own trailer, I used angle iron, with exhaust clamps, which then clamped to handlebars, don't know if you will have room for similar?
Cheers........
I am suprised the bike moved around when travelling as it is pretty much what we have. As long as that bar is tight down over the seat and you have the front wheel ratchet strapped into the end of the rack it should not move. Are you sure it wasnt the rack that was moving? The big difference between mine and yours is how the rack is secured. Ours goes into the chassis at a much wider entry point than yours which makes it very stable.
I am sure with your incredible technical skills though that you will fettle it!
And yet there are so many who do it without problems, I have a bike rack that fits on the rear wall that will safely carry 75kg, if it is rated at 75kg it would have been tested at more than double that to receive that rating, I cannot see a scooter rack on the back of that MH being any where near the limitI assume you have taken the precaution of putting your MH over a weighbridge with the scooter on board and all the other bits you will be travelling with.
My Hymer S700 has a payload of 2000kgs which sounds great! But then I have to deduct the weight of all the Big Boys Toys on the roof (Sat TV, aircon, solar panels, fill up the tanks, add two bodies, luggage and a bottle or two of Bombay Sapphire!!!
My Hymer, being based on a Merc Sprinter Twin Wheel has a long overhang behind the twin rear wheels. Add the extra length added by the scooter rack and your scooter weight multiplies because of the leverage effect.
I had a scooter rack on the Beast when I bought it, but got rid of it because I was concerned that there was a hell of a lot of weight outboard of the hitch plate and the scooter and rack were supported by just two bolts. A towing hitch supports downward force, whereas your scooter rack has a much greater and possibly dangerous force line.
I'm not too bothered about the weight and the rear axle that can be measured and I'd hope you knew what you had spare.
