Comments,Idea's Welcome
  • Thread starter Thread starter Flyboy
Flyboy
Hi everybody see what you think about this fire i am working on its half a 7kg gas bottle with a piece of 1/4in metal plate welded on the back.
I will be setting onto ceramic tiles attached to some cement board (fire board ) on a 2" frame which will be packed with fireproofing
Not sure if i should put an air gap between the fire and the wall panel as this is the side of the fridge.
View attachment 15037View attachment 15038View attachment 15039
Is that canopy decorative or is there some sort of flue?
What happens to the combustion products?
Just Decorative No need For A Flue.
I Think you Would Have to be in a near sealed room with no air flow in or out before you start to feel any affects from the small amount of co that is produced by the fuel.
Most self builds have enough natural gaps in the doors seals to allow air flow in and out but you should always Er on the side of caution as with anything misuse and not using common sense can lead to problems.
It looks fab, you could easily add a wall mountable removable fireguard too if needed, just thinking about clothes etc brushing against it, although I don't think the metal would get hot enough to cause fabric to flame, but possibly singe.
Please explain? Why is there no need for a flue?
If you're burning fuels inside a small space you will need to let the exhaust gases out, somehow.
We've been thro this before, the fuel is bio-ethanol (pretty much like meths) and the proponents believe it is unlikely to produce enough CO to kill. It seems that the fumes are not enough to activate CO alarms. Will be a fair bit of condensation tho I guess.
I am not qualified to answer any of the questions with regards to the manufacturing process of Bio-Ethanol or with regards to Health and safety matters when using the product.
Some Notes Taken Off the Internet Might Help Answer Some Question
No chimney, lot’s of freedom
An ethanol fireplace is actually a quite simple construction, and because of the fuel (denatured ethanol) – there is no need for a chimney or massive installation. Since it doesn’t need a chimney, it’s a mobile fireplaces – that is, the floor models of course. Having a mobile fireplace is great in many ways: if you move you can take it with you, if you change the decor you can move the fireplace, you can take it out on the patio – and many more.
No dangerous fumes
Unlike burning wood, the ethanol fireplace doesn’t omit any dangerous fumes when burning. Thats actually the reason it doesn’t need a chimney – the fuel is so clean that the final product of the flame is a very small amount of water and carbon dioxide (and don’t be afraid, you won’t get wet walls or suffocate, see the Con about oxygen for more info).
From ashes to… Nothing!
Having such a clean flame also gives other benefits. Of course you don’t get any ashes as the remaining liquid vaporize, but another thing is soot. You won’t get any soot on your walls or ceilings. The only places we ever se soot is where the flame touch, and even then it’s a very very little amount (did i emphasize the little part enough? – it’s basically nothing!).
What is biomass, what are bio fuels?
Biomass is the total dry organic matter or stored energy content of living
or recently living organisms. Biomass can be used for fuel directly by
burning it, indirectly by fermentation to an alcohol, or extraction of
combustible oils. Biomass also includes biodegradable wastes that can be
burnt as fuel.
Bio fuel is a fuel that is derived from biomass. It is a renewable energy
source; the CO2 released when it is burnt was absorbed from the
atmosphere during plant growth.
Bio fuels include:- Bio ethanol, Bio butanol, Bio diesel, Biogas
Launched into the last comment without the benefit(?) of reading the thread started by WVW. OK I'm a bit stuck as to how the assertion is made that the fuel never produces CO. Gas generally doesn't if burnt in the right conditions but of course it can.
I've now done the compulsory half hour interweb education programme. Looking at those lush orange flames as methanol quite often burns colourlessly, does it have an agent added to colour the flames? As it's orange guessing a sodium salt(?), do salts in solution flame like solids? though if burning it won't be in solution.
I presume this substance is spiked to stop me substituting it for vodka in the cocktail. Is it a bittering agent or am I adding milk to produce a "Eths" white lady? Denatured alcohol - Wikipedia, the free encyclopedia
If in Europe denatured alcohol as ethanol is often available we would have traditionally seen it as a substitute "Meths" but as ethanol it is a cheaper option for bio ethanol.
Well, Smaug, thanks for your reply. Might I point out however, that I hadn't read thro ALL of the threads pertaining to this "incab" heater that you allude to. You guys may well have been through it all before but others don't always read every blessed post that's ever written, especially when there's no link back to the original thread from whence this thread has sprung.
I'm not keen on producing yet more moisture inside my van, as this burner will (there's enough of that from the diving gear) so I'll stick to my DRY AIR producing, Carbon Neutral, Free Fuel (pick it up anywhere, especially way out in the sticks, even in mid-winter) Logburner which vents nice and safely thro the roof.
Ciao for Niao
DT
The flame does change to blue after about 10 Min's of burning you ignite the fumes and not the fluid
bio ethanol fuel consists of waste from several agricultural products including as maize, potatoes and wheat. The waste from these products is used in a fermentation process that results in what is essentially a form of alcohol. The alcohol then has some additives included to make it harmful to drink! The resulting liquid is then bottled for use as an environmentally friendly fuel in our Bio ethanol fires. When burned, the result is water, steam and low, safe levels of carbon dioxide (CO2). Bio ethanol fuel is considered an environmentally friendly fuel as the amount of the CO2 emitted on burning is offset by the CO2 collected by the plants when originally grown.
I think I would rather keep the 7kg gas bottle full with gas and use that to heat my van the conventional way. Looks like a bit of MFI backboard with decorative bits that have no real function
Sorry, but thats how I see it
Well I think its decorative, effective, and obviously safe. The people who saw Steve's van were all impressed by his attempts and his knowledge.
Some of us simply dont have the money to buy heaters and what not so this could be a much cheaper alternative !!!
I'm certainly no expert on this so the below is more a question than an answer.
My very brief googling of bio-ethanol suggest that the bi-products of the combustion process are water and Carbon Dioxide. This is, i'm assuming, is based on adequate oxygen being present to lead to complete combustion.
My understanding is that in an area where there is less than adequate oxygen, large heat-sinks, and a few other factors (that I don't fully grasp TBH) then the combustion process will be incomplete, leading to other byproducts.
So my question - Is there any risk that the size of vehicle, the type of burner/presence of heat-sink and type of existing ventilation may lead to a situation where the combustion process is incomplete leading to production of carbon monoxide (or other by-products) in potentially dangerous quantities?
There is always "a risk," the discussion is about how likely it is. Most seem to think it's not very likely if there is good ventilation (which rather negates the heating effect).
As long as the assessment of 'likelihood' is based on a reasoned logic then fair-enough.
I deal with a lot of risk assessing of things and I find that quite often, while the 'hazard' element has been well researched/understood, the evaluation of the 'likelihood' of the event has often been guessed based on a lack of understanding. Usually falling into either the 'it'll never happen' category or the 'it's gonna collapse any minute' category, and missing everything in between. More importantly, when pressed on the derivation of the 'likelihood' of the event, people often have no real answer other than to simply re-state the hazard, or re-confirm that they don't understand the situation.
The above isn't meant to sound narky, I just like to check that people are making decisions like this based on an evaluation of info rather than a lack of it.
simple answer is yes, In the LPG world, there are strict regulations in respect of Ventilation Upper/lower their location etc in respect of the volume of the primary habitation area. Partly because appliances such as cookers are flueless.
In the link Flyboy quotes, there is a mention of soot, which is a product of incorrect combustion, therfore not unreasonable to assume Carbon Monoxide is present.
0.01 % or 100 parts per million of co in the air produces 13 percent saturation of Co in the blood stream slight headache
I quote that not to frighten anyone, but demonstrate the concentration of Co doesnt need to be high to have an effect.
As Smaug and Flyboy suggest it is all to do with risk assessment and likelihood.
Channa
Like all heaters that burn hydrocarbon fuels and do not have a flue leading to the outside, the heated space must be well ventilated to allow the combustion products (water vapour, CO2 and CO) to escape and fresh air for combustion to enter, and this applies to paraffin, gas, or ethanol.You Must Keep a good air flow in and out of the van
I think the answer is in your own Question
It all comes down to Adequate Air Flow This allows the fuel to burn at the correct temperature and reduces the amount of fumes/ unspent fuel that are released into the atmosphere.
I was interested to note recently that a family had some members die recently after taking a Barbie into a tent for warmth. Now, I would expect a tent, even with a built-in ground sheet to have adequate ventilation, however I suspect that closing the Barbie lid (to reduce risk of fire) would create the conditions for low oxygen burn & CO production. I don't know if that is what happened, just trying to think about situations where CO could have been produced.
You think about the times you have slept in a tent woke up to condensation on the inside thats down to ventilation or lack of fresh air flowing though . Could this be something to do with the Hydrostatic Head (waterproofing Levels ) of the tents not allowing free air flow.
