Pudsey Bear
Absolutely, we have gas CH, but also a gas fire in the lounge, electric hob/oven, if the power goes off we have the van on the drive so we're covered in reality.
I would no way have gas heating as you are not allowed to service or touch it, and apart from it may go BANG.Absolutely, we have gas CH, but also a gas fire in the lounge, electric hob/oven, if the power goes off we have the van on the drive so we're covered in reality.
Will the central heating work if there's a power cut?<snip>
Why have a gas fire when you have c heating, dont make sense to me.
Did you delve into checking out how everything is mounted? If vibration from the fans is being transmitted into the cabinetry then it'll be noisy for sure. Even outlet pipes pushed up hard against the cabinet or walls will transmit unwanted noise.Well back from a short trip where we used the heater and I paid more attention to what makes it noisy.
The noise is in equal quantity from the burner fan, and the cooling fan. At start up the burner fan makes most of the noise and at shut down, the cooling fan, equally noisy runs on for some time after it has stopped burning. If you use it for room heating, the blower fan to circulate the hot air adds almost nothing extra.
Listening to the fans, neither of them sound broken, worn out, or noisy bearings. Just noisy fans blowing air. So unlike others I still cannot recommend a diesel heater as a good quiet option.
I do have a sound level meter, so perhaps in due course I will go and run it and take some noise readings, but without a benchmark to compare my readings with another set is a bit meaningless.
My only comparison was my previous gas water heater in my last trailer caravan, which would be 20 years old now if I still had it. The gas burner was as inaudible as a gas hob burning, and the flue fan was almost inaudible. The loudest "noise" that ever made was a clonk when the thermostat turned the gas valve on or off, and the very quiet tick tick tick as the spark ignition light the flame.
My van came with an underslung tank and a nearly empty 11KG bottle in the gas locker.is there any way when you have a fixed LPG tank you can somehow have say a 6kg Calor as a backup?
I have never found anyone who can manage on solar in winter in the UK. You can go days or weeks with effectively zero sun.How do you manage to live off grid in the depths of winter? Must be a pretty good solar set up.
I think Barry misread my post I didn't claim to live off solar in the winter I use LPG and was making the point that LPG is still very much an option for some people, especially those who live full time in the UK in the winterI have never found anyone who can manage on solar in winter in the UK. You can go days or weeks with effectively zero sun.
I've found several.people who claim to only use solar, but they use a generator, hookup or b2b on a regular basis.
If it happened again, I think I'd just fit a hose and blow into the pipe. A little air in the system wouldn't do any harm.low side, which simply meant turning the bottle on for a few seconds
It isn't true to say I never used the bottle.
The regulator on the tank developed a fault and would sometimes lock out.
The way to unlock it was to put pressure on the low side, which simply meant turning the bottle on for a few seconds.
This happened maybe half a dozen times in a year or two, then I fixed the problem.
At that point, the bottle was even nearer empty, so it moved to the shed, where it presumably still is. That shed is falling down and opening the doors is a non-trivial task.
So although it is possible to have a tank and a bottle, few would bother, with bottles being so much more hassle and far more expensive.
LPG is generally around £1 per litre (£2 per KG) at present, which is far cheaper than diesel, KWh for KWh, but bottled gas is at least twice as expensive, plus the gas wasted if you swap a bottle before it is empty, or the hassle if you wait until it runs out.
I like refillable gas: convenient, powerful and cheap. But swapping gas bottles is a real hassle. I'd never want to go back to that.
??? @barryd waits till the Calor is empty, so not wasting any.
Seems odd.They are only 6kg bottles so they don't last that long. Couple of weeks or so in summer but less if you start using heating.
I can't quite get my head round the idea of switching to a swappable bottle when you still have some gas left in a refillable. Why would you do that?
In the last 16 years I have never run out of gas. I top the underslung tank up long before it is anywhere near empty, or whenever I pass LPG at a reasonable price.
Seems odd.
Our tank easily manages two or three months, even running a big fridge freezer and some heating and hot water.
Yes, it is about 28KG of LPG, but I guess 6KG would last more than a fifth as long, and our van is presumably a bit bigger: the gas locker easily holds 2x13KG.
Are you sure you dont have a leak?
