Mtbcol
Lookout it's me again
I'm going to supplement our lead acid leisure battery with our ecoflow delta 2. The leisure battery is currently hooked up to my victron mppt.
Once the LB is fully charged when we're parked up, if the delta 2 needs topping up I plan to disconnect the solar panel from the mppt ( I've got MP4 connectors before the mppt and also plan to put in a breaker as it will be easier) then connect the panel to the DELTA2 with the appropriate leads. Do I need to disconnect the mppt from the LB each time I do this, and does it matter what order I disconnect in if I do need to. I know on initial set up you don't in a particular order.
This is only a temporary set up as once funds allow again I'll be replacing the lead acid LB with a lithium.
Thank you.
Colin
Thank you.
Colin
