Stands for levelling system
Boris7
I’m about to make 4 stands to replace the wooden blocks I use when the levelling system can’t cope with uneven ground. Basically they will be aluminium and fold flat when not in use to save space, they’ll be about 20-25mm thick and 100-120mm square when not in use and about 100-120mm high when in use.
Before I go about this does anyone already have something similar off the shelf?
We had massive plastic blocks forthe Concorde came with it, decided after a few uses to give them away at a meet, they wear impressive but at nearly 9 ton we didnt go on grass , but when we did i ended up digging them out after we moved away
Similar to this
Similar to this
No, there idea for spreading the load, but when the ground is uneven you need blocks to go under the legs. Issue is the amount of room taken up by the blocks when not being used.
I’m thinking of this (poorly drawn for now)
120mm high when in use 20mm high when not in use.
Hmmm never had that problem it just used to level itself we could also tip it side to side to empty the big black and grey tanks ,
What weight is vehicle and might be worthwhile looking at some of the plastic pallets the have tapered square blocks that slide into one another you could cut some blocks off them that are stackable
The issue is I don’t generally use campsites, as an example at Donington park the ground I park on is on a slop and uneven, so I carry lots of blocks and they are a pain to put away each time. At Brands Hatch I used to leave some old sleepers at the circuit, but some scroat nicked them.
The plastic pallets may be worth a look, but I have access to a plasma cutter and folder etc.
I have some rear stabiliser pads in the garage some where. It would be very easy to drill a hole through the centre, do the same with a block of wood, then pop a bolt through them to hold them together.
No need to use a nut if you want instant dis-assembler.
Or contact Scotia who can knock something up in metal.
I have some blocks slightly larger than you are looking for but they can be used to jack up on and they stack so they don’t slip off each other, here is a photo. They are about 25cms square and about 5cms thick, material is I think glass fibre reinforced HDPE.
Thanks, I might come back to you on that.
We used to have something very similar, powder coated green with a rubber mat on top to prevent slipping. Can't remember who made them but we found that they weren't particularly stable. The design of the slotted internal cross pieces meant that they were prone to twisting, Heavier gauge sheet might have solved the problem as would slots in the top and bottom plates.
I made some in 3mm aluminium in the week and yes they worked, but I’m going 4mm and 200mm square with better locators.
Also sandwich profile tops that slide onto the legs to avoid slipping.
