Probably just a quirk of the electronics. That sort of weird stuff happens all the time with 'tronics when they're asked to function outside of their normal operating range.
If you've got a couple of hundred watts of solar or more then you'll probably be able to keep both batteries topped up over winter without using the EHU. Y
Depends on where you are (see table below) and what devices are on.
e.g. in Aberdeen you will get about 10ah per day which will support an average draw of less than 0.5 amp.
whereas those overwintering in Marbella will be getting over 4 times this.
Had the same problem with our Phantom alarm recently. According to Phantom the microwave part of the alarm system is typically very sensitive to low temperature fluctuations. If it’s persists in triggering they suggested putting it in pet mode which turns off the ultrasound but still sets the perimeter. (Press the button again after 5 seconds). Tried that and it worked. A few degrees warmer now and it’s working properly again.
