Paul38
Why get 240V Fridge (we don't use 220V in UK)? How does £700+ saving sound as a reason?w
The UK voltage label was changed years back from 240v to 230v to harmonise with the rest of Europe. This new 230v label however came with a huge tolerance of +10% - 6% which encompasses all UK and EU voltages from 216v right up to 253v so that nobody had to actually change their supply voltage at all. As a consequence we still use exactly what we've always used.....240v. Call it what you will but nothing changed except the label.230v here and im sure mainland the same.
My average voltage where I live is 243VWe'll 220/230 then we haven't had 240 in the UK for years now ☺
Should I bother to argue a point with someone who doesn't even know what voltage is present on a UK mains socket? nah, don't think soI do agree with your point on price but a lash-up will always be a lash-up do the job once and do the job right
Tested mine here and reading 231v.The UK voltage label was changed years back from 240v to 230v to harmonise with the rest of Europe. This new 230v label however came with a huge tolerance of +10% - 6% which encompasses all UK and EU voltages from 216v right up to 253v so that nobody had to actually change their supply voltage at all. As a consequence we still use exactly what we've always used.....240v. Call it what you will but nothing changed except the label.
Mines similar to David's and always over 240, and usually 243, highest I've seen is 245.Tested mine here and reading 231v.
It's funny but I've got a lot of vintage electronic equipment from the 50s and 60s, way before the 'harmonisation' of UK/EU voltages when we supposedly had a standard 240v mains. Many items have a voltage adjustment plate on the rear which often enables a massive range of adjustment to the mains voltage 200-260 volts in 5 volt steps isn't unusual.Mines similar to David's and always over 240, and usually 243, highest I've seen is 245.
* The exception is refillable gas. If you are going to install an underslung gas tank, or a refillable bottle (no point in fitting two), the sooner you do it, the better sense it makes.
The mice are running to fast round the wheel.Mines similar to David's and always over 240, and usually 243, highest I've seen is 245.
Some of use think outside the box.240/220 it's still AC and your van primarily is DC how dose putting a house hold fridge in your van make any sense that's with out going down the road of earthing AC on the move the doors don't stay shut things fall off the shelves mostly they don't fit well they dont secure well . But there cheap ok crack on . (And just for a wind up IEC 60038)![]()
Good evening friends.
Looking ahead to when we finally purchase a motorhome, what are peoples thoughts on powering a fridge? Pretty certain whatever we buy will have a 3 way fridge, and from what I've read they are not very good/ efficient. In our current self build we have a small 240v compressor fridge which we run very successfully with our solar panels, battery bank and inverter. Without a doubt we will replace the 3 way fridge with a compressor unit, the question is should we go with a 12 volt unit or a 240 (domestic) unit run via our leisure battery/ inverter set up? Obviously we will need a fridge unit that is roughly the same size as the unit we remove, so maybe will need a bit more power either way? I also expect a purpose made motorhome fridge will be much more expensive than a domestic one. Your thoughts and ideas are most welcome. Thanks. Colin.![]()
From my experience, a compression fridge is way more efficient than a thermal fridge, i.e. a 3 way. The idea of taking 12V and using an inverter to get 230V is SO inefficient. Transformers are passive, inverters take power even if no load, but if intelligent switch off and don't come on again. I have no qualms about runing my fridge (plus security system) 24/7 even if not driving with the back-up of an 80W solar panel 8 months of the year. You need a compression fridge/fridge-freezer designed for 12 V plus solar panels.Good evening friends.
Well, that is correct if you are talking about electrical efficiency. Over a typical 24 hour period, a Compressor Fridge uses approximately 1/7th the power of a 3-Way FridgeFrom my experience, a compression fridge is way more efficient than a thermal fridge, i.e. a 3 way.
However, THAT is such an incorrect statementThe idea of taking 12V and using an inverter to get 230V is SO inefficient. Transformers are passive, inverters take power even if no load, but if intelligent switch off and don't come on again.
I love the way people like to make these absolute statementsI have no qualms about runing my fridge (plus security system) 24/7 even if not driving with the back-up of an 80W solar panel 8 months of the year. You need a compression fridge/fridge-freezer designed for 12 V plus solar panels.
Thing is though, if you've already got an inverter that's keeping the other half happy because she can "do her hair properly" with a proper hairdryer and straighteners and you're already cooking using an induction hob, air fryer/ microwave and doing your toast in the morning with a domestic toaster then the van isn't primarily 12v..... it's primarily 230v so fitting a domestic fridge instead of a 12v compressor fridge and saving several hundred quid makes perfect sense to me. This is the way I'll go if/when I dump my current 3way which incidentally doesn't keep it's contents on the shelves particularly well either whilst travelling. I really don't see the issue, a 230v fridge works well, is comparable in efficiency, yep a suitable fixing method and door catch needs to be addressed and of course this will be the stumbling block for some but for those who are handy enough to take on the task then the much cheaper 240v fridge is perfectly viable surely?how dose putting a house hold fridge in your van make any sense
Because Chris......what you have there is merely a lash up. You need to remove it and do the job properly.Why do folk try to make things harder than they need be. I have a household fridge with separate freezer compartment, cost about £100.
