oppy
Hi folks and help, our solar panel controller has gone blank ,the van electric seems to be ok, any ideas or advice please
Peter
Peter
Anonymous, sorry, Amazon purchase a couple of years agoWhich controller is it Peter? What make and model?
I think "disconnect +ve to panel, reconnect +ve to panel." would be exactly the same.
a) check voltage across the panel output terminals.Hi folks and help, our solar panel controller has gone blank ,the van electric seems to be ok, any ideas or advice please
Peter
I thought disconnecting the battery would force the mppt to reset itself?I think "disconnect +ve to panel, reconnect +ve to panel." would be exactly the same.
Only reason for disconnecting battery +ve is to avoid having a loose live wire around if the job is going to take a while.
If you do decide to disconnect battery +ve do it at battery end rather than controller end.
If the panel is disconnected, which I clearly instructed, disconnecting the battery should reset the controller, it will not damage the controller.No that will bu==er up the control unit big time.
Sadly my van multi tester is on my bench back home, I forgot to put it back.............bloomin eejit that I ama) check voltage across the panel output terminals.
b) check voltage across the panel input terminals (when the sun is shining)
c) test all fuses in system
d) tell us the results.
Good Luck
Sadly I cannot find a fuseA typical solar controller appears dead when the fuse has blown.
Definitely worth testing the voltages before mending it with a new one.Ah well, thanks folks for your advice but I now think that it's kernaked, but hopefully our batteries will last our stay
Yes if panels disconnected first, i have seen folk not do this.
Some have a built in fuse (like Trevs), others are fused through the Hab fuse system. I don't know what van you have and if it is a British model, I would be of no help anyway. I had foreign vans. It's worth checking the main fusebox, or tracing the wiring back (yes I know, almost impossible in a motorhome, especially at our age).Sadly I cannot find a fuse
