Dometic fridge not clicking on gas
Clunegapyears
Grr. The f/f worked fine 3 weeks ago so it hasn't all seized up.
But now it thinks it is working on gas, as no error message. I know we have gas.
But what is strange is that it is not even clicking to fire up when I switch it on and off. Well, it gives are half hearted double click and then goes silent.
I tried YouTube but hopeless.
Any ideas?
When my fridge did this it was one of those grey boxes with the pnk label or the one with te white label because it’s a different fridge to mine I’m not sure which box it was but I got a new one for £60/70 off eBay and some kind person replaced it the wires were just pull out spade and a couple of screws to hold the thing in place but I can’t remember what it was called.
Note I’m no expert nd could be completely wrong.
If you post the fridge model number, it would help with suggestions, it is on a label inside the fridge.
Annie is right in the suggestion of the ignition module (IMO) it has been covered a few times, I think that it was I who suggested it to Annie but I could be wrong , I am always suggesting something 🤣
When the module fails it either doesn't click or continues clicking even with the gas lit
AAA battery behind the ignition button?
Interesting but it would still help to know the model number, my fridge doesn't have a battery, obviously there are some that do after watching that video but I have never seen one, RM8000 are late models
Yes it was you and you found me the correct one on eBay. 💋
View attachment 141916View attachment 141917
We had a new controller unit 18 months ago, thinking that was causing the previous fridge problems. In the end, it was a blocked supply! But, fortunately, I have the old and probably OK controller, with us!
But could do with identifying the fault before we pay to replace it. Ho hum ... there's always something!
At Fiat in Heraklion atm ... fixing cab heating, so will see if I can identify the ignition switch and clean it. The clicking stops, so reading the above and link to previous Annie's issue, it sounds more like that.
BTW, no ignition battery. And I'll dig out the model no.
Thanks guys
Fixit man in Hetaklion then stopped answering our calls so he was obviously too busy!
We won't be using the mh between now and end July as house guests and will fly back to the uk when my first grandchild arrives.
So I'll book repairs on the Greek mainland. There's a newish place near Athens that has a free serviced aire. They can look at the heating that also only works on electric! The joys of a modern motorhome in its 8th year!
Thanks for the comments and thoughts ... reckon ignition switch.
UPDATE
We ferried from Crete to the mainland and were booked straight into a moho service centre east of Athens.
They replaced the switch between fuel (wot Annie suggested) and the fridge fans. Apparently Dometic recommend fans over 30C. They put the fan control switch inside as apparently they regularly seize up inside the vent at the back of the fridge.
They also put in new gas filters ... we'd had some, but for some reason, during a recent service, they'd been removed. All working.
Until the next morning! We were 3 hours away, so we kept going to the service centre near Thessaloniki. The mechanic went through everything. Replaced parts to check if that was the cause, then put our part back. Compressed air through. You name it, he did it. He eventually removed something from the exhaust. Said it was causing the flame to go out. Given the van is nearly 9 yrs old, this seems unlikely. However, it is still working.
Well, working as much as it can in temps generally 38 - 40C!
