wildebus
Yup a jigsaw will produce swarf hot enough to damage paint (I regularly have to cut 300/400mm holes through steel painted panels for ductwork work wise)
Even using a jigsaw with fresh blade ....
I cover the actual cut area (and outside) with good quality masking tape ...to prevent damage from swarf and the jigsaws action
And below it with paper and masking tape to prevent marking from hot swarf ...
Once the hot swarf has damaged the panel it's too late IMHO ...and easily preventable with some simple prep work .
part off-topic, part on-topic .... A handy thing to do when cutting or drilling holes in van metalwork is to have a magnet where you are cutting. Fillings will attach to the magnet and the cleanup operation becomes less of a chore.
Also, if you put a bit of clingfilm around the magnet then it becomes very easy to clean the fillings off the magnet itself by just removing the clingfilm.
