wildebus
As the battery approaches fully charged, the charge current drops more and more and the final 20% or so will take a lot longer to get to full charge compared to say the time spent taken to take a battery from 50% to 70% SOC.I've checked a few up to the £280 mark and they all have charging current restrictions. This one https://www.alpha-batteries.co.uk/12v-leoch-pure-lead-carbon-plh-c100-deep-cycle-leisure-battery/ has a 30A limit and frankly looks like a superior battery to the cheaper Leoch ones.
The problem with adding resistance to the charging circuit to get you below 20A is that you've got to limit the 20A to when the battery is well discharged and as the battery charges the charge current will fall off meaning the charge time will rise. If you fitted a 20A B2B you'd get 20A continuous reducing the charge time considerably,
The chart that Victron gives up within the Smartphone App for their B2B to show the user what to expect shows this kind of sitution and is spot on.
The top line is Voltage and the bottom line is Current.
The charge phases of Bulk and Absoption can be - and are actually better - more accurately described as CC (Continuous Current) and CV (Continuous Voltage) mode, and the chart above illustrates that perfectly.
Personally speaking, I would not attempt to add resistance to the cabling to lower charge current as in reality you'd find the battery is the limiting factor in the first place (unless it is a very poor battery which demands a very slow charge rate)
Typically basic lead acid batteries have a charge rate of C/10 (10A per 100Ah) and better AGM and GEL batteries tend to go for around max of C/4 (25A per 100Ah).
This is where Lithium really excels where it will charge at a much higher rate of up to C1 from empty all the way to full with no dropoff (basically it charges in CC mode until full and then goes to float, bypassing CV mode)
allow £100 for the B2B plus the 115Ah LC battery and you're under £300, alternatively go for the one above and add enough resistance to keep charge rate at 30A at say 75% discharged, you'd get a reasonably fast recharge from the alternator.
Going back to LA will be cheaper but it probably wont last as long so you'll be swapping it sooner with all the extra hassle that goes with it, I guess it's pays your money and takes your choice.
Good luck with whatever you choose to do![]()
