Filling a gas it system
I've not seen a reason online for why you should have the valve closed, but I would assume having thunk a bit about it, it might be that there is a much higher pressure coming into the tank/cylinder whilst filling it than the tank itself would normally have, which could overload the gas regulator, this would then possible cause the appliance taps to fail, but then I would think the brains that make the regulators would have put a failsafe in them to prevent that.
But not found any useful info.
The suggestion is that the input pressure provided by the pump is significantly greater than the regulator deals with in service.
It is a precautionary measure to protect the regulator.
I have recent experience filling with LPG in Spain. At one garage the pressure was so high that the cylinders would not fill. I suspect that there is protection built in to protect my GasIt cylinders.
The disconnection of the filling hose was extremely violent, indeed quite frightening!
I went to another nearby garage and filled without any problem...
Probably becasue your Spanish fill valve didn't have the valve in it
You'd think that info would be easy to find.
Although I did find this just now but no such instructions came with the cylinder or filling kit.
Every single cylinder listed on Gaslow's website says "Always turn the cylinders off for filling"
