But having a dig at a sexton is more serious, some might even say, grave exerciseYeah, but having a dig at you is far less fun though![]()
Is that what those rings inside with copper wire wrapped around them are for Merl? torroidal or something.Any decent manufacturer will add some sort of protection against these transient spikes and the long term ability to cope with not having the battery connected will depend on how well this protection circuitry is deployed.
Are you sure that switch disconnects the solar panels? It would make much better sense to have a fuse in the battery lead at that point (to protect the controller, not the cable, in a fault condition). I do have one of those in a drawer. I'll try and remember to check what that fuse does.The votronic has a fuse fitted which can be pulled if required.
Yes all in the instructions, and i have everything fused in my setup, im not a fan of the one bit does all in factory vans, most are junk.Are you sure that switch disconnects the solar panels? It would make much better sense to have a fuse in the battery lead at that point (to protect the controller, not the cable, in a fault condition). I do have one of those in a drawer. I'll try and remember to check what that fuse does.
I'd expect it to be on the solar side. As covered previously the controller needs a battery on it's output for protection so a fuse at that position would be potentially harmful rather than protective. BUT you do see some strange things sometimes!Are you sure that switch disconnects the solar panels? It would make much better sense to have a fuse in the battery lead at that point (to protect the controller, not the cable, in a fault condition). I do have one of those in a drawer. I'll try and remember to check what that fuse does.
I erred on the side of safety and had a fuse on the + above the roof and inside where it came in and also next to the LB +, I put fuse anywhere a + went through metal and grommets too on all circuits.
I actually have fuses after the panel cable comes into the van as I didn’t realise the Votronic fuse did that when I first got it. I also have a Victron controller though (one panel to each) so it wasn’t wasted
Dont fuse the battery side of contoler as if it blows then damage to unit may happen, do fuse all components wired of the battery.
