RoadTrek Boy
As for ohms law it has always worked for me.
Sorry but Road trek boy and Colinm have got this one right.With respect I think it is you that is wrong.
There is no mention of watts on the charger plate just volts (100 - 240) and amps (max 25).
A watt is a measurement of power.
Devices do not have a fixed wattage, they have a fixed resistance which is measured in Ohms.
The relation ship between voltage, current, resistance and power is stated in two established laws of physics.
a) Ohm's law.
"The current that flows through conductors is directly proportional to the voltage applied to it.
In formula terms V = IR where V = Potential difference (volts); I = Current (amps); R = resistance (ohms)
In other words if the voltage is reduced the current will also reduce.
An example is leaving a vehicle headlights on without the engine running.
After a while the battery voltage is reduced, when this happens the current is also reduced.
b) Electrical Power law
The electric power is given by multiplying the potential difference by the current.
In formula terms P = VI where V = potential difference (volts); I = electrical current (amps); P =power (watts)
In other words if the voltage is reduced the power will also reduce.
As the voltage of the car battery decreases so will the brightness of the bulbs and this is what happens in the real world.
Now returning to the Charger.
The higher the input voltage the higher the current (as per Ohms Law) so the 2.5 amp will be when the input voltage is 240v.
Using the Electrical Power law, the power is 2.5 a x 240v = 600w
If the input voltage is reduced to 100v
The current will be reduced (Ohms law) the power produced (Electrical Power law) will be reduced and thus the scooter battery will take longer to charge.
This is illustrated by people using an air dryer in countries using 110v mains, when the operation takes longer.
A lot of scooters have more than one battery, mine has two but a lot cheaper than Pudsey li-on setup.Why not buy a spare 'chair battery' as a backup if you need to use the chair on a second day?
