Moped
The fact is if a van has an internal GRP skin damp proof meters do not work. They can only detect damp in wood as this causes the resistance of the current generated by the damp detector to change as it reduces resistance.
So if a van has an internal GRP skin, it is impossible to test for damp using a prong meter. So if a van has this internal skin then manufacturers do not incorporate any wood in the sandwich between the inner and outer skins.
Are you absolutely certain that you Roller Team van does not have a marine ply inner skin?
The GRP inner skin acts as a vapour barrier as it does not permit any damp to pass through it. In addition the insulation material in the sandwich has similar anti damp properties. So the spore issue is a non starter.
So for anybody who has a damp meter and it shows readings when using it on the inner skin of the van, then the electricity the meter produces to generate a reading has to be passing through wood. It does not pass through GRP.
Try using the meter on the GRP outer skin of the van. It will not read.
