Apart from the ability to have your awning out no matter what surface you are parked on, I don't see the advantage.
What am I missing?
use bulb-tite rivets Rob. Excellent load spreading on blind side and waterproof tooOrdinary rivets do not really lend themselves to fitting the bracket too well, but rivnuts and short bolts would.
nah.. the setting force is no more than a "normal" blind rivet so shouldn't damage the bracket . Trouble with rivnuts is that they can "spin" especially in thin gauge material (and they have to be carefully set too)
(I used to be the West Mids technical sales rep for Gesipa many many years ago) ideally I would need to see the actual plastic bracket..
Here you go Tim;
View attachment 108872View attachment 108873
There is also a rubber pad to hold the bracket off of the paintwork behind the bracket.
they look well robust enough Rob. why not bring one with you the weekend and I can measure the counterbore & depth etc and maybe recommend a rivet solution if you want?
Why dont you fit a clamped bracket coming out under the sill, it would work for both front and back fixing points.
When I get a bit tired !
I use "Yawning brackets"
yes mateSpot on Tim will do.
Are they fitted with a standard Rivet gun?
I’ve done a similar thing to this but I’ve modified 2 glass lifters (can’t send photos as I’m away working) but this sort of thing Here they work a treat and no drilling.
Sounds good. But the left one narrow enough to fit in on a B Pillar?
