jagmanx
Are you related to Michael Barrymore or Jonathan Woss ?The Japanese use that method still. Every worked on Toyota radio wiring? 30 odd wires .... All white!
Aircraft are all white wires with numbers, in ww2 Boeing used ferrets in the B17 assy line to pull the wires up tubes from point a to point b.All the control wiring on the coating plants used white wires, they were all numbered though but only one end. Wasn’t good when we cut one multicore as we thought it would be quicker to rewire.![]()
Somehow I seem to specialise in weird ones!
Now I find my Elnagh Marlin has all its cabling polarity reversed!
Brown = negative and blue = positive.
Frequently not important but when it is, its easy not to remember and get it wrong...
But why on earth wouid they do it like that....
A lot of the cabling/wiring inside an electric cooker has a switched Neutral and not a switched Line.If ac pos live hot side and neutral are reversed it is dangerous, live must always be on the switched side, yes many ac goods will work but its very dangerous.
I suppose this reduces the voltage at contact and so contact erosion.A lot of the cabling/wiring inside an electric cooker has a switched Neutral and not a switched Line.
Just me or are these missing on server?
Sargent PSU seems to have a polarity check light.Or one of these which i have.View attachment 89940
Not just youSargent PSU seems to have a polarity check light.
All you have to us remember to rummage in the cupboard and look at it when you hook up
One gathers that our soon to be ex EU cousins are less fussy about how they wire up mains?
No, it isn't just youJust me or are these missing on server?
Positive and negative = dcAre you referring to 12v or 230v? If 12v then manufacturers can use what colours they want even if it has the potential to confuse, found that out with GM who used black(or was it black/grey?) as +ve. If it's for 230v, then in many countries they often don't seem to worry about live/neutral colours.
No the object may be still live even if switched of on 230v ac.I suppose this reduces the voltage at contact and so contact erosion.
Or is this a misconception?
I was edumacated up to ONC in electrical engineering so am well aware of that, however due to OP mentioning brown and blue, and then -ve/+ve he may have mixed up terms, it often pays to double check this on forums.Positive and negative = dc
Live and neutral = ac
The thing is, when you are taking your UK made Motorhome to the continent, you are very often also taking your standard UK switches & breakers with you, which are single-pole and thus only isolates just the live - or is it just the neutral? (who knows with continental mains systems....when you say “polarity is reversed” are you referring to the AC mains system or the 12v DC system?
on continental mains systems, polarity isn’t an issue.... AC (alternating current) appliances will work whichever way the colour are wired. When switched, they use double-pole switches which isolates both circuits, just the Earth (ground) needs to be correct.....
I think it is obvious to anyone that has a German built motorhome that he was talking about his 12v DC system, it would have been better if he confirmed it thoughI was edumacated up to ONC in electrical engineering so am well aware of that, however due to OP mentioning brown and blue, and then -ve/+ve he may have mixed up terms, it often pays to double check this on forums.
