cheersSteve ,i tried to pm you but it wouldn't let me. i've ordered one now , i needed to up from 16a to 20 as my planer keeps tripping the switch on start-upYep, Denmans. I have an account Nige, if you need to use them.
What do you need? I may even have it.
Hope your wiring is up to it.... Fuse is there to protect the wires more than what's on the end of them...
Breakers also come in different ratings...
Motor rated breakers allow for the start ramp up current without tripping....
Something wire fuses were a bit better at dealing with ;-)
well i cancelled as the guy said he couldn't get any Ctypes . do you reckon a c16 might do it ? since i moved here i've just started it by slowly upping the trip switch,but it won't do that anymore ,probably worn it out !To add to what you've said, cable properly fused at 16A will probably (should) be 2.5mm2, which in most situations would be fine to fuse at 20A.
Also, yes, probably need a C type breaker, not B. However, the current increase may well work anyway.
