KuusamoMart
I'm having a lot of issues with the sliding door showing as open and unable to lock the van. The door doesn't shut perfectly and there is no more adjustment on the lock and striker assembly. If I lean on the door slightly, it will register as closed and I can lock the van, however, as soon as I release the pressure, the alarm goes off. I removed the contact assembly from the door and used a drill bit to push the switch operating pad to its fully extended position (it was fully retracted previously), but when I closed the door, the problem occurred again; I had a look at the pad and it was partially retracted, so had obviously contacted the switch, so I cannot understand why the setting was lost. Any ideas why this doesn#t adjust correctly?
