Johnnygm7lsi
Looks like its 800 Ah so more than enough
I just found one that says up to 800 Ah and also this one
The D250S Dual refines all DC sources including alternators and solar power, to perfectly match the amount of charge the battery requires whilst minimising charge time. The D250S Dual is a 20A multi-step charger that automatically adjusts the charging voltage and current according to the battery state of charge and temperature to ensure that the battery is safely optimised for performance.
90% efficiency
Adapts to parallel energy sources, use with alternator, solar or both
Automatic starter/service battery separation
Input voltage 12.9-22V DC; 14.4V Charge Voltage
Max charge current 20A; charges batteries 40Ah to 300Ah
IP65 rated - splash and dust proof
Temperature sensor
2 year warranty
There must be a few versions of the D250S
My life support is....13.5 volt/5amp
ok, so does it use a power supply that plugs into a 13amp socket
It can when I have mains power but when in the van I plug it in to a car 12 socket(you know the round type,ciggy lighter type)
You wouldn't need a voltage regulator then, just a cig lighter socket wired to the 4x1100`s you can get them from Halfords for a few quid
But my life support will alarm when I flush the loo or any other high drain if I just plug in to a 12v outlet due to the voltage drop (I think)
I didn`t read back thru the old thread, but I thought the reason for the extra batteries was to keep the life support independent of the hab batteries, so the life support had its dedicated power supply, but I remember now about the alarm going off, it may be, that it will not happen with the higher capacity of extra batteries
You might be as well getting a small inverter to run the power supply of the life support, if its only for the life support it wouldn`t need to be a big one
The USA one does 13.5 volt and is up to 10 amp (spot on) but $350
The UK one is 12 volt and 5 amp Only just enough and is £30.00
ERMMMM
I`ll have another google and see if theres a better one, may be better with a little bit over 5amps, that was the first one I came across
would this do it?
150W Boost Converter 10-32V - 12-35V Step-Up Voltage Regulator Power Supply PSU | eBay
If I read it right as long as the output is higher than the input its ok up to 6 amp, 12 volt in and 13.5 out but the volts in would go up when the mains battery charger is on,would that be ok?
