Bigpeetee
There has been a number of threads on WiFi extenders.
Just bought this from ebay:
41dBm Mini Desktop WiFi USB Booster Planar Antenna Set | eBay UK
It's a USB wifi booster that comes with two antenna, the first a rubber antenna that gives omni direction (all around) and a flat planar antenna that is directional, a bit like a dish.
For £23.99 inc p+p I think it's great value and took 8 days to arrive from Hong Kong.
For example, in my dining room I went from 4 wifi base stations to 12, one going from very poor to excellent. The Planar antenna gave even more.
So how does it work in the van?
I parked up in Llandudno, using the laptop I got a couple of signals, when I used the booster with the omni I got loads of signals, including Bt Openzone, the cloud and Mc Donalds.
With clear line of site from the top of the Great Orme, I used the planar antenna on my dashboard, I could get signals from Anglesey if I pointed the antenna at Anglesey or Loads from Llandudno itself if pointed there.
The planar antenna could do with a plastic box if it's to be left outside for any time, it comes with a mount and I just fixed that to a piece of ply.
One word of caution, the booster uses a lot more power than the internal wifi so the battery of the laptop won't last as long.
Looking around the internet, there are conflicting reports as to the maximum power output a wifi should be, these boosters are between 5-10 times the recommended power. Not a problem if you are away from anything, but use them at home and you could start to cause problems with other wifi users locally.
Rule is: only use it if you need to, anyway, it flattens your battery quicker when in use.
