landoboguy
I have a 2019 Autotrail Imala, and am upping the batteries to be 3 x 120ah lead acid along with solar upgrade etc. Im looking for advice if the exisiting charger is up to it.
The psu is a Sargent EC176 which includes the charger, now info on this 176 is very sparce to say the least, but am told the EC175 is all but identical apart from button placement.
My question is , if we assuem zero (or very little leisure load when on EHU) mis this charger spec below in the EC176 (175) good enough to get my 360 ah 12v up to full charge and float ? it seems a bit flimsy. I seem to remember a charger should be min 15% amp of the batteries.
If its not, any recommends on upgrades/exchange. I have emailed Sargent, and am awaiting a reply in the new year but though the knowledgeable folk here could shed some light. The only info I have is from the 175 manual below. Any advice appreciated.
John
"The EC175PSU incorporates a fixed voltage battery charger / power converter. The battery charger / power converter also powers the leisure equipment when the mains supply is connected.
This module supplies 13.8V DC to the leisure equipment up to a maximum of 12 Amps (155 Watts), therefore the available power is distributed between the leisure load and the battery, with the leisure load taking priority as per the following example:
Leisure load Available power for battery charging
load /available for charging
3A - 9A
6A - 6A
9A - 3A
12A -0A
For optimum performance and safety it is essential that only a proprietary brand LEISURE battery is used with a typical capacity of 75 to 120 Ah (Ampere / hours).
WARNING Under heavy loads the power supply unit case may become hot. ALWAYS ensure the ventilation slots have a clear flow of air. Do not place combustible materials against / adjacent to the EC175.
The PSU will shutdown if overheated and will restart automatically when cool.
EC175 Power Control System Issue 1 Page 6 of 14 20 July 2014 3.3 Leisure Battery 3.3.1 Type / Selection
For optimum performance and safety it is essential that only a proprietary brand LEISURE battery is used with a typical capacity of 75 to 120 Ah (Ampere / hours). A normal vehicle battery is not suitable. This battery should always be connected when the system is in use. The PSU is configured to work with standard lead acid leisure batteries, and in most cases is also compatible with the latest range of Absorbed Glass Matt (AGM) batteries. Before fitting non-standard batteries please check that the fixed charging profile described in 3.2 is suitable for the type of battery by referring to the battery documentation or battery manufacturer. The battery feed is fitted with an inline fuse between the battery and the electrical harness, which is usually located immediately outside the battery compartment or within 500mm of the battery. The maximum rating of this fuse is 20A.
John
3A - 9A
6A - 6A
9A - 3A
12A -0A
