Warwick Duo Rear Doors (2015)
motorwaycafe
Rear door close but instrument panel says they are open, so the central locking will not work.
I’ve cleaned the side door connections ( linked to rear doors) but that has not solved the problem.
Do any of you know how the wiring circuit is linked?
All advise most appreciated. Garage suggested changing all the locks!!
Thank you Colinm. I did that the first time several years ago and it worked well.
This time I replaced the previous packing but without success.
Cheers.
Is it on a Renault Master? If so it is a common problem - there are videos on Youtube to instruct how to bypass the alarm.
If it is a Renault I will try and locate the fix for you.
I'll post it anyway in case any other Renault/Vauxhall/Nissan owners are having the same problem.
Thank you Robmac for thr video. My vehicle is Boxer Van chassis which has a different configuration, but no doubt similar electronics..
Just found another video on this problem, if you skip to around the 9 minute mark it shows how he fixed the problem although it may be a different problem on yours.
