bazzybabes
Hi winksWill that not be attempting to introduce low pressure gas into a point designed for high pressure filling.
I would think that if you are regulating the pressure down to 30mbar or so, the best option is to connect to a Barbecue point or on to a bottle pressure supply and use the existing regulator. I'm assuming the second item is a clip on regulator.
Cheers
H
Yes that is exactly what you want.
Cheaper and easier than messing about with lpg too
Please tell Charlie . . . easier than Google give.With that set up you should also be able to transfer some lpg into your onboard cylinder if you wanted but I will leave you to google how to do it and whether you want to .
Re Barry's reference to Morocco, is refillable LPG hard to come by out there?
