I agree but if Garmin Express thinks you're on a mobile network then the IP address is the only way I can think of how it knowsShouldn’t need a VPN if your in the UK
I have 5G at home, but I still had problems. I know you are more experienced than I am with Garmin, so why do I have problems? I don't know, but I got around it itYou need a good strong 4g or better still 5g signal and that the quaterly updates ( new maps ) can be big, as much as 10GB depending on model.
If it thinks your on a mobile network that will be because it’s NOT connected to the WiFi or the devise settings need looking at.I agree but if Garmin Express thinks you're on a mobile network then the IP address is the only way I can think of how it knows
A VPN connected to a UK IP might just fool it.
Regards,
Del
I'm referring to the public IP address not the local IP address, the public one will be the same even if you're connected to the WiFi, in fact I'm pretty sure the Garmin wouldn't connect directly to a mobile network unless it had it's own SIMIf it thinks your on a mobile network that will be because it’s NOT connected to the WiFi or the devise settings need looking at.
If your mobile phone or other WiFi device is working simple go to google and enter “check my location” if that comes back as correct do a speed test, if that’s ok it’s not your network, it’s the garmin.
Now go to garmin and check it’s logged into the CORRECT WiFi a/c. If not change it, if so go to settings and check that the devise is set to allow updates via WiFi
I haven’t a SIM card in my Garmin but it seems to update each Friday sometime only briefly others a bit longer.I'm referring to the public IP address not the local IP address, the public one will be the same even if you're connected to the WiFi, in fact I'm pretty sure the Garmin wouldn't connect directly to a mobile network unless it had it's own SIM
Regards,
Del
