rough costings please to do job ,pj
This is from a doc I made at the time:
GASIT TANK INSTALL Using metal and parts available at the time.
Parts obtained from :
GAS IT Refillable LPG Gas Bottles and Gas Tanks Solutions. - GAS IT Leisure Gas - Catering, Motorhome, Campervan, Caravan, Farrier and Road Repair Refillable Gas Solutions. - GAS IT Leisure Gas Bottles, Gas Cylincers and Gas Tanks - Catering, Motorhome, Campervan, Caravan, Farrier and Road Repair Refillable Gas Solutions.
1. 270 x 40 ltr GAS IT Horizontal Vapour tank £230.48
2. UK bayonet JIC fixed fill point Straight.£18.94
3. Black Square dust cap for UK bayonet fill points that have been mounted under the vehicle or on a tow bar.£5.98
4. 270 diam x 40 ltr High Quality OEM specification GAS IT Cylinder Tank frame with 2 Straps - fully UK and EU certified product £26.04
5. A pair Heavy duty 1300mm x 30mm Powder coated Cylinder Tanks Straps and buckles - Sold with 2 Straps, Buckels and Fixings £17.21
6. 1 mtr JIC Fast Fill 'Hydraulic Style' E67.01 Hose with Straight Ends.£19.39
7. Straight fill point bracket long galvanised pre-drilled £7.44
8. 8mm copper pipe x 1mm wall thickness, black powder coated and fully marked up with approval number all the way down its length. £6.44 per metre @ 5 metres =£32.20
9. GAS IT's straight in and out Mini vapour filter for any underneath Vapour tank with 21.8 LH gas outlet thread fitting.£29.99
10. GAS IT's NEW Micro 30mb Motorhome and Caravan Regulator with Straight outlet £17.33
11. GAS IT 9 led contents guage and tank sender £45.83
12. GAS IT 0.45mtr Fully Stainless Steel Pigtail 21.8 L/H x W20 £26.31
13. High Quality 1 way brass low pressure Shut off tap / Manifold for 8mm pipe in and out £12.37
14. Bullfinch bbq point inc housing £39.29
15. Gaslow Reserve Cylinder Connection Hose £16.50
16. 8mm tee from local plumbers merchant to get correct male or female connections £1.50 Total £546.80 plus delivery,but ask for discount as you are a member of a motorhome forum etc .
17. Will be 10% cheaper if collected from Bristol depot
Avon Autogas | Convert your car to cheaper, greener and cleaner LPG
