Sharon the Cat
New Rimor on a Fiat Ducato base.
Plate says 79 psi, tyres say 69 psi.
Hmmmm?
Hmmmm?
Hi Andy, so does the tyre rating count for anything?79 is a bit hard,
I would go with 70 and see how it feels,
I’ve dropped mine to 60 only to stop the rattling from all the lockers
That will take some homework, thanks.What does the tyre company (provided its not Michelin) say based on your actual axle weights when loaded?
You wouldn't have been posting that for a toilet thread, would you?Another tyre pressure thread!!!!!!
Burstner say 79psi all round. I use 65psi on the front axle, and 75psi on the rear for the last 3 years+ on Winter Tyres all year. The ride is a little firm, but the tread wear has been uniform, and the strengthened tyre walls give a sensible level of support and protection over the potholes that pass for UK roads.New Rimor on a Fiat Ducato base.
Hmmmm?
Sorry Andy but that's not correct.The tyre pressure written on the side wall is a general recommended pressure for an average vehicle,
As others have said lowering the pressures will give a smoother ride but Steve hasalso pointed out the important bit which i have highlighted bold.Burstner say 79psi all round. I use 65psi on the front axle, and 75psi on the rear for the last 3 years+ on Winter Tyres all year. The ride is a little firm, but the tread wear has been uniform, and the strengthened tyre walls give a sensible level of support and protection over the potholes that pass for UK roads.
Steve
The value to which you refer is Max Pressure. This is a value that is required to be given to meet USA requirements. It is not a guide to the inflation pressure for any vehicle. The pressure is determined by the axle loading as determined on a weighbridge and reference thereafter to the tyre manufacturer or as calculated by Tyresafe:
Motorhome Tyre Pressure Calculator | TyreSafe
Our motorhome tyre pressure calculator gives you the correct pressures for your motorhome. Check your tyres regularly for your safety.www.tyresafe.org
Or the website here:
Motorhome Tyre Load and Inflation Tables | TyreSafe
The correct inflation pressures for your motorhome's tyres are extremely important. Here is some information to help with your motorhome tyre pressurewww.tyresafe.org
The website doesn't ask for the make.So the tyres say maximum inflation is 69 psi and the website is saying 80 psi!
No wonder things go wrong in this world
Just out of interest what brand n type are the tyres , my autosleeper has vanco camping tyres front 70 psi rear 80 psi .as stated on the tyre pressure plate so that is what I use ,
But, having said that, I have no idea what all the numbers and letters on the tyre mean. Apart from m i c h e l i n of course!
