Tunit box and internal screens.
maingate
I am changing the van shortly and the following 2 items are available.
Tunit Box for Ducato 2.8JTD 2002 - 2006. £150
Internal screens for the same model. £20
The Tunit was flashed over with the latest software around 18 months ago (by Tunit).
I also have a K & N Air Filter (needs cleaning but I also include the cleaning kit). £20
Maingate - check your PMs - message sent for the Tunit
A little box that alters engine management to give better performance/economy....allegedly.
The Tunit Box is a brilliant piece of kit, one of the few tuning boxes that actually do what they claim. I have run one on a VW tdi and it was fantastic.
I have one on my motorhome, I have been playing with the settings and there does not seem to be a difference between the settings one and nine.
http://www.wildcamping.co.uk/forums/wild-camping-motorhome-chat/33898-tunit-engine-management.html
Thanks very much for that link Beemer. You have just cost me the sale of my Tunit box to an interested member. :mad2:
This thread is not the place to bitch because yours seems to be faulty. I could probably give you good advice as to what is wrong but I now have 150 reasons why I will not. Would you now please stay off this thread.
If I find out that mine is faulty, I will be the first to come back on this thread and tell everybody.
I am truly sorry that you seem to think that I cost you the sale of your Tunit box, but I have just said it how it is, I did not rubbish the tunit box or state that yours is not worth buying.
I did not bitch about the Tunit box either, Obanboy666 asked about it, I have one and gave my view. If you feel you do not wish to give 150 reasons why you would not give advice, that is obviously up to you entirely, ask me if I am bothered, but I doubt very much there are 150 reasons.
Here is the quote from your link......
"Ever since I bought our latest m/h with a TUNIT box already fitted, I have wanted to test it somehow, to find out what difference it makes.
Last weekend I decide to have a look at the box and see what setting it is on and then change the setting to see if there is any difference.
I noticed that the TUNIT box was set up to number 5 on the tuning dial so I recorded 60mph (indicated on speedo) at 2600 revs, and 70mph at 3000 revs. I then changed the setting to 1 on the dial and recorded exactly the same, then to 9 on the dial and... er..exactly the same!!!!"
The result is bound to be the same as unless you change the gearing, then at X rpm the result will always be Y mph. It's that simple. You would need to put your MH on a dynamometer to record the power and torque curves vs. throttle position to see exactly what changes and tuning box or re-chip gives.
You really shouldn't have posted your comments about your tuning box not working if you are basing your misinformed findings on engine rpm vs road speed.
Mmmmm.. is it lets gang up on Beemer night tonight?
Here is a quote from you.....
To start with I did not claim that my Tunit box is not working and my findings are not misinformed, I said it as it was, how can that be misinformed? They are my findings..I didn't get them from anywhere else except me!
Secondly, and this is why I don't understand the group attack.... and I quote from my link:
Is my test not a good test or do I have a dummy TUNIT box fitted?
I sort of expected to see a drop and a rise in the revs for each setting... or should I look for something else?
The cables to the box disappear behind the engine so are difficult to follow to see where they go.
This is the bit you forgot to post... they are questions ... which indicates I may not be fully conversant as to what the Tunit box does!
I did get some good answers, if you read the link.
No where do I say that the Tunit box is crap or don't buy one off anyone, it is just my opinion/findings with mine.
Some people like to cause trouble by reading into other peoples posts and coming up with some ridiculous rubbish.
Oh dear, I didn't include the last part of your post because it wasn't really relevant, apologies if you think it was.
The settings 1-9 in your case, will probably affect the fuelling and not the engine revs. The throttle position affects the revs. The road speed, mph, is directly related to the engine revs in any particular gear so is not a variable that will be affected by the tuning box.
What you can reasonably expect is that you would use less throttle for a given speed or to put it another way, your engine would produce more power for a given engine speed.
As a simple rule of thumb, the higher the number, the more power, now assuming that you drive your van in the same way, you should find that it will pull better, particularly up hills or on long motorway inclines and you should get better fuel consumption, probably in the region of 10% - 20% as a result of using less throttle for a given rpm.
You may find that the higher number settings will produce black smoke, (over fuelling), especially when you put your foot down, if this is the case then go to a lower setting until the black smoke disappears. On the other hand, if the engine management light comes on, this would also indicate an incorrect setting.
The cables that disappear, (there are usually 2), go to the common rail, where the standard cable normally plugs into the end of the common rail, the tuning box simply fits in between the standard cable and the common rail.
Any queries, speak to the supplier, in your case, Tunit, who are really helpful.
Once again, apologies if I upset you, but so far, between us, we have managed to hijack the OP's thread, so apologies there as well.
I disagree, the last part of the post was the whole point of the link...I was asking for help and I got it!!
I also disagree with hijacking the post, because it bumps the OP's proposed sale to the top of the list again! I am sure there are people who read the whole thread and don't take it out of context.
nearly forgot... thank you for your information on the Tunit box.
If the sale has fallen through I am interested in both the tunit box and the filter, I am still at Rutland Water but if you still have both pm me and we can sort something out
Hi tezza,
I will pm you with contact details etc.
Hi, not wishing to throw fuel on the conversational fire so to speak, I personally have found that most claims to greater fuel economy or power, from fuel additives or enhancers (hydrogen on demand production) or chipping or programing seem to be more for controlling the drivers, driving than the vehicles performance.
I produce Bio Diesel, and run both main vehicles on this, and have found a benefit in performance and fuel economy, how much of this is related to a possible change in my driving style I’m not sure, I think it’s possibly a little psychosomatic. You think it’s made a change so you convince yourself as much, but each to their own.
If you are going to throw things at me, please make it money.:nicethread:
Just in case nobody has noticed, this is the FOR SALE section and not general discussion forum......
somebody tries to sell something and as long as there is no misleading content or attempt of fraud, people should
not post in this thread unless they want to buy!
just my own opinion of course
I am going to throw verbal abuse at you.
If you have a point to make then start your own thread. :mad2:
Thanks Teutone for reminding them that this is a thread purely for selling motorhome related items.
1:Obanboy666 asked a simple question “Showing my ignorance, whats a tunit box ? “
2:Beemer gave his honest opinion of his experience with said device, he was then berated.
Clearly we must ignore all questions that are not in the right section, what an open minded helpful forum that would make us. We have all had experiences with different devices doing different things, that means we all have different views on their effectiveness or value, or would people prefer that we only give our opinion and answer questions when no one has one to sell?
As I said before .... start your own thread.
Too many people ask questions and other members have to take time to tell them. They could google it instead or do a search on the forum but they don't do that.
